About time you guys bought an oscilloscope. A lot of things should be much clearer with it.
ltseung888
Quote from: robbie47 on October 28, 2009, 08:34:36 AM
Lawrence, do you re-use the back-emf of the drive coil(s) after switching off the current?
This might be the effect you indicated.
Instead of calling it back emf, we understand it as the AC component induced after the current was switched off during the Pulse. It may be the same thing as what was used to recharge batteries by Bedini.
We detected it today.  We have not used it yet.
It may be another blessing from the Divine One.
robbie47
Lawrence, another question after browsing through this thread to understand your principle:
You mentioned several times "The Minato, Newman and Bedini Motors relied on pulse with one frequency.  At other "non-optimal" frequencies, the efficiency would be low and cannot achieve overunity"
What so you mean with "one frequency"? Their machines generate pulses that are synchronized with the rotation, so this is a variable frequency (= repetition)
I think you mean fixed pulse length instead of fixed frequency. Correct?
ltseung888
Quote from: robbie47 on October 28, 2009, 09:20:30 AM
The Newman machine uses reel switch.  That gave me the notion that a single frequency was used.  Bill and others correctly pointed out that the Bedini system uses coil to detect when to pulse.  In other words, variable frequency was also used.
The real question is â€" what is wrong with the Bedini Motor compared with the 225 HP Pulse Motor?  The Bedini Motor could barely demonstrate overunity and could charge some batteries.  The 225 HP Motor could generate 225 HP.  Some would say that the 225 HP is a hoax.  Some would say that a top secret project such as the 225 HP pulse motor would never be leaked out.
I would say that the Lead-Out Energy theory can easily explain the energy source of the 225 HP Pulse Motor.  The Newman, Bedini, Minato etc. Pulse Motors failed to match the 225 HP Pulse Motor.  Their inferior technologies are allowed to circulate.
We are lucky to have the Divine Blessing (or failed at least 7 times without giving up) to be able to demonstrate overunity from the Input and Output meter readings.  The use of the HK$10 Proximity Switch (PS) allowed us to observe the process clearly.
1.   Slight adjustment of the PS allowed speed up, slow down, stop and even reverse rotation.  It showed the importance of the control mechanism.
2.   The PS functioning time was short compared with the “idle time” on a large wheel.  This allowed full Lead-Out of the gravitational and magnetic (electron motion) energy.  Many Bedini experimenters did not understand that.  They went for small wheels and fast rotational speeds.  That destroyed their chances.
3.   We have the advantage of having and believing the 225 HP video.  It gave us the rough dimension and rotational speed (1 m diameter and less than 100 revolutions per minute).
4.   We put the video on the Internet and none of the Forum Members picked up such valuable information.  (Many are paid agents trying to discredit the technology).
5.   We now realized that the “idle time” is not really idle.  The drive coil is actually picking up energy in the same way as the collector coil.  The Bedini circuit actually uses this energy.  We may examine and modify that circuit.
6.   We realized that the drive coils on our large wheel could also provide the “collector coil” energy already.  We achieved overunity without using this energy yet.  This tells us that our Wheel is far from optimal efficiency.  We are also way behind the 225 HP Pulse Motor.
7.   We are not disappointed as we relied on a part-time person with a monthly budget of less than HK$5,000 compared with the resource of the Governments.  Our work is likely to force them to turn the top secret project to civilian use and benefit the entire World.  (Governments such as USA, China, Japan, Russian etc. already conducted research in same field.)
In the coming Inno Carnival 09 on Nov. 5-8 at the Hong Kong Science Park, our Dry Run is NOT to provide the final solution.  Our goal is to show our experimental results so far and the Lead-Out Energy theory.  We invite and expect disputes, discussions, insults, jeers and cheers.  One important result is to stimulate scientists to look more closely at the Lead-Out theory.  The overunity prototype is just the bait.  We can win the Nobel Prize with the Lead-Out Theory and a proof-of-concept prototype.  We cannot build the commercial 5KW electricity generator or the Flying Saucer that beat the classified work of the Governments in the Tong Garage!
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
ltseung888
This thread contains too many early thoughts, half baked ideas and insults.  You will learn faster by reading:
http://geocities.com/ltseung
