ltseung888
Quote from: robbie47 on October 28, 2009, 08:34:36 AM
Lawrence, do you re-use the back-emf of the drive coil(s) after switching off the current?
This might be the effect you indicated.
In the picture below re-using driving current in the coils can be found.
Solution 1 uses a diode to re-circulate drive current after switching off
Solution 2 uses simple switch to re-circulate current after switching off
Are your using something like this?
Keep your constructive ideas flowing.
It is 7 days before the Show.  We have frozen all development.  The whole focus is on preparing for the Open Show.  We need to do at least the following:
1.   Beautify the two Demo Systems.
2.   Train at least 4 helpers.
3.   Prepare the promotional material that will be handed out
4.   Prepare the explanation material so that the helpers can impress the visitors
5.   Do the posters
6.   Write the Press Release
7.   Coordinate with the Invention Associate, the Commission for Innovation and Technology and the Six Universities.
8.   Write the speeches for the Press Interviews
9.   Buy and prepare all backup material â€" additional batteries, lights, wires, etc.
Mr. Tong also wants to show the scope readings but he has not mastered its operation fully yet.  That may be a surprise bonus in this Show.  It is likely to be an included item in the other coming shows.
robbie47
Quote from: ltseung888 on October 28, 2009, 08:18:52 PM
This thread contains too many early thoughts, half baked ideas and insults.  You will learn faster by reading:
http://geocities.com/ltseung
Lawrence, thanks very much for taking time to answer my questions. I really appreciate it.
Can you check the link to geocities ? It does not seem to work...
I got a message: Sorry, GeoCities has closed
Another question: can you provide any technical info or a web link to the HK$10 Proximity Switch (PS). I like to understand this switch a bit better.
Good luck with the show!
ltseung888
Quote from: robbie47 on October 29, 2009, 04:54:55 AM
You are right.  Geocities has closed.  We shall update and put the information elsewhere later.
I got the Proximity switch from DHC in Shenzhen.  FAX 8368 2620.
It is day 6 before the Open Show.
The strategy for promotion at the Open Show has been decided.
It is Lead-Out Energy, Lead-Out Energy and Lead-Out Energy.
1.   We are in the Inno Carnival 09 to tell the World that there is indeed pollution-free, abundant, available-anywhere energy.  Examples are gravitational and magnetic (electron motion) energy.
2.   Leading Out such energy does not violate the Law of Conservation of Energy.
3.   The best explanation is the Pulled Pendulum.  The work done by the vertical component of the tension of the string multiplied by the vertical displacement is the Lead-Out Gravitational Energy.
4.   The demonstration prototype extends the theory to Pulsed Rotation in both gravitational and magnetic (electron motion) fields.
5.   The overunity factor can be confirmed from the Input and Output meter readings.
6.   We cannot provide products for home use yet.  But we are willing to share our research results with those interested in research, development and producing products.
7.   We invite the academics and the engineering experts to seriously examine our theory and our prototype.  We shall let representatives from the Commission of Innovation and Technology and the Universities of Hong Kong to examine, disassemble, improve and re-assemble one of the prototypes.
8.   We provide a Five-Day training course for Companies who want to research and produce products in this field.
They will have a working prototype to examine, disassemble, improve and re-assemble.  They can keep the prototype after the course.  The price of the Course is HK$150,000.  They can send up to 15 employees to the course.  They can wait for the reports from the Universities before signing up.
Some of the Courses will probably be done in conjunction with the Universities.  The advantage is the much better equipped classrooms, laboratories and the prestige of the Universities.  They are welcome to visit the garage shop of Mr. Tong Po Chi and see the Birth Place of Great Inventions.
ltseung888
Press Release from Help Seedlings Innovate Foundation Limited (HSI)
On Oct. 5-8, 2009, at the Inno Carnival 09 event in the Hong Kong Science Park, HSI will demonstrate the Lead-Out Energy Prototype.  This Lead-Out Energy Prototype is based on the Lead-Out Energy Theory explained in the patents by Mr. Lee Cheung Kin and Mr. Lawrence Tseung in 2005.
The Lead-Out Energy theory states that everything is immersed in gravitational fields.  Object A is attracted by Object B.  When Object A moves towards Object B, work is done (or there is an energy change.)  This energy exists all the time.  If we can lead it out (or use it), we do not violate the Law of Conservation of Energy.
The best example of using such energy is the pulled pendulum.  The gravitational energy that can be lead-out is equal to the product of the vertical component of the tension of the string multiplied by the vertical displacement.  So long as there is tension in the string, gravitational energy can be lead-out. Mathematically, if we apply 2 units of horizontal energy to pull the pendulum, we can lead -out 1 unit of gravitational energy.
The theory was published and discussed since early 2005.  Now, HSI has a prototype developed with the help of Mr. Tong Po Chi.  The Prototype confirms the above theory.  The Input Energy is less than the Output Energy from the meter readings.  This is known as overunity.  We invite the academic and engineering experts to examine, disassemble, improve and re-assemble the prototype.
We are confident that the results will confirm the Lead-Out Energy theory.  This means that we can use (or Lead-Out) the existing energies around us.  The prototype will Lead-Out both gravitational and magnetic (electron motion) energy.  The Lead-Out Energy is pollution-ree, abundant and available-.everywhere.
Our goal is to benefit the entire World.  We are not in the position to provide products for home-use yet.  However, we want to share our research results with those who want to research, develop and produce products in this exciting area.  Thus we offer a Five-Day Course for Companies at the price of HK$150,000.  The Company may send up to 15 employees and HSI will provide a working prototype for the course participants to examine, disassemble, improve and re-assemble.  The Company may keep the prototype afterwards.  The Company may also enter into commercial  agreements with HSI to do joint research, development, marketing and product sales.
In addition, HSI has invited the Sponsors of the Inno Carnival 09 â€" the Commission for Innovation and Technology and the Universities of Hong Kong to send their experts to study the Lead-Out Theory, to examine, disassemble, improve and re-assemble one of the prototypes.  They are encouraged to write their independent reports.
Hong Kong may become the Innovation Mecca of the World.  Hong Kong is likely to lead the World in this area of Lead-Out Energy!
With Lead-Out Energy, the energy crisis of the World is over.  Lead-Out Energy, Lead-Out Energy and Lead-Out Energy.
TheDivineOne
Quote from: ltseung888 on October 30, 2009, 03:32:58 AM
For lack of timely payment for my divine guidance, you released the wrong dates for the trade show.
