0 Members and 18 Guests are viewing this topic.
Paul-R
Quote from: broli on November 02, 2009, 05:29:49 PM
Just make sure when you start it up it runs unlike Steorns orbo demo...
There is a view that Steorn may have been using traditional stage lighting,
each lantern having the usual 1Kw lamp. The heat from them may
have heated some magnets above their ? Curie temperature, thereby
demagnetising them.
The Observer
Dear Mr Tseung and the Rest,
I would like to thank you for your persistence on this matter of Lead Out Energy.
I have personally started two threads here at Overunity, both of which most likely apply to your lead out theory.
_______________________________________________________________________________________________
        The First Thread pertains to Magnetic Permeability... http://www.overunity.com/index.php?topic=4831.msg101674#msg101674
                  Electron Energy is lead out when when a solenoid turns a piece of iron into a magnet.
                   That is... the solenoid has a magnetic field 5000 times more intense with the piece of iron !!!!!!!!
           Why? Because the iron already had a huge magnetic field...something most people don't realize.
         Although, this example does not use resonance, I did theorize that a Resonating Iron Transformer could display an OU effect.
                 So I did buy an electronics kit, figured out how to resonate (with a 1.4 volt battery) the audio transformer and hense have
                  brightly lit 3 volt LEDs (many at the same time) on secondary.  (keep in mind this is a STEP DOWN transformer)
                  I also found 40 volt pulses on the front side which will charge the largest capacitor on my board to over 15 volts in a few minutes.
__________________________________________________________________________________________________
     The Second Thread pertains to the fact that an Acoustic Guitar rings louder and longer than an Electric Guitar.
         The proof that more energy is being emitted from the Acoustic Guitar is a 1st year physics problem.
                     find the proof in the middle of this page.... http://www.overunity.com/index.php?topic=7810.30
        It is debated that the duration of the Electric is far longer than the Acoustic to account for the extra energy.
            This is False ! Basically you can't stop something from ringing by using it's natural frequency.
                                     In fact.. it's opposite. Think of the the two tuning fork experiment.
                                     You keep something ringing by using it's natural frequency.. it's call forced resonance.
__________________________________________________________________________________________________-
I did want to give my blessing to your trip and endeavor.
May the Sun Shine on Calm Waters,
                                                             The Observer
utilitarian
Quote from: Paul-R on November 03, 2009, 10:37:13 AM
demagnetising them.
OK, it's not like the Steorn demo was held in the 1800's where no one is sure of what happened.  This was only like 2 years ago, and there is video of the event.  There was no 1KW stage lighting.
And the excuse was made about overheated bearings, not magnets.
ltseung888
One more day to go
We found out that to win the Overunity Prize from Stefan et al, the Output should at least be larger than Input by 1 watt.  Mr. Tong used a FIVE Collector Coil set up.  The required result was achieved with no problems.
The other problem we found was that Stefan allowed only 20Kg for the winning prototype.  We have to think about reducing the weight in the coming weeks.
We have another charming helper, Ms. Chen Lai, who can speak fluent Putonghua.  She might help out in Shenzhen or other parts of China.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
Make sure you put new batteries in that multi meter before you leave.
