Top Gun
Ways to control runaway current
Since this is a unique problem specific to Overunity Machines, I doubt that there is a ready solution.  It should be fun to outline the various approaches here:
1.   Blow the fuse on the feedback circuit.  This would surely stop the increasing current.  However, the machine is expected to continue to function for some time.  The wheel will still rotate due to its momentum.  The PS will still pulse.
2.   Use a circuit breaker that can be turned back on easily.  This is the same as solution 1 and may be acceptable at the Open Show.  Make the effect much more dramatic.  The audience will love it.
3.   Reduce the number of Drive Coils including 0.  There will be no battery supplied current to the coils.  However, there may be feedback current.  This may turn out to be a demonstration that removing the battery is entirely possible after starting.  It may be a pleasant surprise.
4.   Drain the Output Energy with additional load.  Sending a sudden outburst of light or sound should be fun.  This will require more thought but it is in line with program control.
5.   Attaching load to the axle.  At high current and thus torque, do some impressive displays.
6.   Stop the function of the Proximity Switch.  If that were too difficult, find another control mechanism such as laser detection and programmed control.  The HK$10 PS has done its job.  It has helped you to demonstrate OVERUNITY conclusively in Inno Carnival 09.  Just let it retire.
Talking about retirement, when will you do your fishing, dear Mr. Tseung?
Top Gun
Current Limiter Circuits
http://www.discovercircuits.com/C/cur-lim.htm
Dear Mr. Tseung,
There is plenty of reading material on Current Limiter Circuits.  You cannot possibly read them all before Dec 3-5.
Now that you are working with the electrical engineering professors at IVE, let them give recommendations.  Let them shine.
I believe the 60 cm wheel is now at IVE.  You can be sure that the professors and their team of students will be working hard to analyze and replicate it.  There is still 3 weeks before the Dec 3-5 Open Show.  My bet is on their successfully implementing a working solution for the 5KW electricity generator before that.
Just go fishing and relax.
ltseung888
The plan for the Open Show on Dec 3-5 at the Hong Kong Convention Center
This Show is a much larger Show than the Inno Carnival 09.  The Hong Kong Convention Center is located downtown.  We have a 3 x 3 meter booth all to ourselves.  There is possibility of doubling that if needed.  We have confirmed support from three professors at IVE.  There is possibility of solving the runaway voltage/current problem.  If that were solved, we could demonstrate the 5KW electricity generator.
1.   We may have Students do the PowerPoint presentation files.  They will be in Putonghua, Cantonese and English.  Hopefully, we do not need to repeat the same words a few hundred times.
2.   We may have the large monitors.
3.   The IVE students are coming up with very bold posters to attract attention.  Examples include: Energy Crisis is Over â€" starting at this Booth.  Come here if you want to be a Nobel Prize Winner etc.
4.   We shall contact the Press well before the Event.  They can have pre-view of the Invention so that they are prepared.
5.   If ready, we shall also show the Educational Product from the Factory.  These will be used in our HK$150,000 training courses.  We can now guarantee that our Educational Products can absolutely demonstrate OVERUNITY.  We shall also give out the cheap digital meters for measuring Pulse Voltage Input.  (The course may even include a comparison between the expensive oscilloscope and the cheap meter.)
After this show, we intend to produce the FREE 5KW prototypes for Beijing, White House and United Nations.  We shall send one to Stefan so that he does not need to pay for electricity any more.
spoondini
Quote from: ltseung888 on November 11, 2009, 08:11:11 AM
[5.   If ready, we shall also show the Educational Product from the Factory.  These will be used in our HK$150,000 training courses.  We can now guarantee that our Educational Products can absolutely demonstrate OVERUNITY.  We shall also give out the cheap digital meters for measuring Pulse Voltage Input.  (The course may even include a comparison between the expensive oscilloscope and the cheap meter.)
Is that a MONEY BACK guarantee that the educational machine demonstrates overunity BEFORE disassembled?  If it doesn't demonstrate OU, what about travel expenses?
teslaalset
Lawrence, it's not quite clear how in practice you will obtain 5kW out of this machine.
As an example you mentioned on page 470 reply #4693 some results of a first feedback experiment.
From this example I can derive that 3.4 W can be consumed without exhausting the battery.
Can you tell us how you will obtain the 5kW you plan to implement?
By just taking a bigger battery that can deliver sufficient charging/discharging current @ 12V?
You showed earlier (e.g. page 474 reply #4735) that with bigger load, the COP decreases.
How would that work with 5kW output consumption?
