Devil
Quote from: teslaalset on November 16, 2009, 05:51:37 AM
FYI, I have started to collect components for replications.
Below bike wheel seems a good start to have an aluminum wheel with good bearings and a diameter of approx. 70 cm (28 inch).
It even has a build in alternator, although it is 6 V (3W).
I ordered it from a German website, it will take some time to arrive.
I am aiming to have the coil mountings adjustable in radial direction, as Lawrence indicated that some flexibility is needed there.
p.s. I am a very slow builder, so don't expect fast progress.
I will keep you posted on my progress.
Lawrence, a few more questions:
1) what kind of magnets did you use? Neodynium? or ceramic? Neodynium ones are not advised in case a soft iron coil core is used. These cores saturate easy because of the strong field Neos have.
2) are all magnet poles facing out in radial direction or facing in tangential direction ?
Use Neodynium and coil with no soft iron.  Mainly facing radial.  Our magnets can be set to have a small angle to get best repulsion.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
teslaalset
@ Devil
What is your relation with Lawrence?
I want to make sure I use same materials as Lawrence first, before using advice of others.
(no offense  ;))
spoondini
Looks like you forgot to sign in as Tseung again 'Devil'/'Top Gun'/'HuFlungPoo'
Tesla - Tseung has multiple sign on's and plays multiple characters.  I picked up on it when he clearly forgot to sign back in as Tseung (as he just did when 'Devil' responded to you) a couple weeks back.
Be very careful dealing with this guy, his activity appears to bordering criminal.
Paul-R
Quote from: Devil on November 16, 2009, 10:06:18 AM
If you do not suggest soft iron for the core, what do you recommend?
teslaalset
Quote from: spoondini on November 16, 2009, 10:36:17 AM
Thanks for the warning. Mark also pointed this out earlier.
Unlike the views of others, I have a neutral position in this thread.
I guess the only way to de-mystify this topic is to replicate and see.
Until now Lawrence is very cooperative in sharing some details so he deserves credits until proven wrong in practice.
Maybe Paul is with me in replicating?
