ltseung888
First Crack at Interpreting the Experimental Results at IVE
The detailed pictures, experimental results from Prof. Chong will be out later.
The following is my personal interpretation.  They are NOT the final results of detailed analysis.
1.   If we think in terms of supplying a DC pulse from a Pulse Generator, we should seen rectangular peaks followed by flat or zero voltage lines.
2.   The actual pulse shape for the Input Voltage from one Drive Coil has three components.  One is the expected rectangle, one is an AC component and one is a flat or zero voltage line.
3.   When we disconnected the battery, the shape consisted of only two components: the AC component and the zero voltage line.  This is the beginning of the slow down period.
4.   The calculation of rpm based on the repeated shape (one cycle) on the oscilloscope was 60 rpm.  The measured value from the speed meter was approximately twice that amount - 125 rpm.
My personal interpretations are:
1.   The Drive Coil in our set up also functions as a Collector Coil.  The Coil is subjected to the effect of rotating magnets.  This will induce AC voltage.  This is a logical explanation of the AC voltage component.
2.   The difference of rpm was puzzling.  One possible explanation is that one cycle on the scope actually represents two revolutions.  When the Proximity Switch PS is off, no current and no voltage will be seen on the scope.  The cheap (HK$10) PS cannot operate above a certain frequency.
3.   Our rotational speed was governed by the limitation of our PS.  As the rotational speed reaches its limiting frequency, it skips its on/off cycle.  Since the frictional force on our wheel will slow down the wheel, the PS works again at the slightly lower rotational speed.
4.   This explains why that the rotational speed does not increase when additional Drive Coils are turned on.
5.   Our INPUT  VOLTAGE measurement was DC.  That should be the RMS value of the rectangular value.  The AC component would roughly cancel itself out.  Thus our INPUT VOLTAGE measurement is similar to that from a Pulse Generator.  The product of this Voltage measurement and the DC current will give the correct INPUT POWER.
6.   The Lead-Out energy or power shows up as: the AC component at INPUT, the AC component at OUTPUT and the mechanical energy available at the axle.
The above explanation fits in with the Lead-Out Theory and the experiments on INPUT and OUTPUT measurements on OVERUNITY.  These important experiments will be explained in a later post.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited.
ltseung888
One minor incident at IVE
When we repeated the INPUT and OUTPUT measurements, we found that the Output voltage was less than 5 Volts.  At the Inno Carnival 09, the value was always over 10 volts.  There was some panic.
Could it be a rundown battery?  We measured the voltage and even changed batteries.  No.
Could it be a shift of position of the coils or the proximity switch during the move?  We double checked and even retuned using the PS. No.
Could it be a loose connection or contact?  Every connection was double-checked.  No.
Then Prof. Chong noticed that his wire to the battery was soft and hot.  Mr. Tong replaced that with the thick wires we normally used.  The value went back up to 12 volts as expected.  Prof. Chong said, “We purchased these wires ready-made.”  Mr. Tong: “Many of such wires look OK but the actual copper wires inside were not because the merchants could make more money with less copper.”
This is one reason why we plan to produce a proper Educational Product with the highest quality control to ensure that OVERUNITY can be demonstrated.
We are getting ambitious.  We think that we can recharge the batteries (with some diode and capacitor circuits) and solve the runaway current/voltage problem.  If we can do that, the Educational Product will have a much greater market.  Just giving the specifications over the Internet and let people purchase any parts with low budgets will be doing the World a disservice.
Lawrence Tseung
Director
ltseung888
The test data from Prof. Chong
The attached excel file is the actual experimental result.
Achieving and Confirming OVERUNITY on the Tong Po Chi Lead-Out Energy Machine is now a piece of cake.
teslaalset
Lawrence, that is interesting data.
A few remote observations from the data presented:
Regarding 'the observed input pulse':
It looks like the input pulse is followed by the induction effect of the passing magnet.
The sinus period part represents the induction period.
So, are the input pulses occurring just before the magnet passes the input coil?
(I remembered you mentioned the magnet first passes the coil before pulsing it, e.g. push it by the pulse)
To have the input voltage pulse shapes is nice to have, but to absolutely prove your values, current shapes at the same time, both for input and output coils will be necessary to convince the septics.
Current shapes could either be taken by using a current probe or measuring voltage over a low resistor put in series with the coil.
Anyway, thanks for sharing this data!
