0 Members and 50 Guests are viewing this topic.
utilitarian
Quote from: The Observer on December 09, 2009, 11:39:52 AM
                                    The difference between energies from Ferro Speaker vs non Ferro Speaker (same sound output),
                                            is the energy that Ferro adds to the system for FREE.
The permanent magnet does not add any energy to the system for free.
The Observer
Hello Util,
In regards to the speaker.
     The total energy needed to drive a speaker is congruent to the total magnetic energy used.
                               Magnet Energy + Ferro in Coil Energy + Coil Energy
     If you can come up with a way to make a speaker sound as loud without Ferro, then you are right.
     If you can not, which I suspect, then it is obvious that energy is added to the system.
The only way to to get close would be to use resonance somehow...
                                                              like how an acoustic guitar body amplifies the string's sound wave.
        But that is an entirely different subject.
Abundant Regards,
                                The Observer
utilitarian
Quote from: The Observer on December 09, 2009, 03:24:33 PM
Hello Util,
When you talk about the ferro, are you referring to the circular permanent magnet inside which there is the coil that moves in and out?  Or are you saying there is another permanent magnet inside the coil itself.  I am not clear.
Here is a diagram.
http://electronics.howstuffworks.com/speaker6.htm
ltseung888
Latest Experimental results
1. The wheel was placed horizontally.  The Input amp meter fluctuated much more.  However, the overunity result was again demonstrated.  The conclusion was that most of the Lead-Out Energy comes from magnetic (electron motion) source rather than gravity.
2. The wheel was better tuned.  The Output with 1 light produced DC 14volts.  That was enough to recharge a 12 volt battery.  We are using four 6 volt batteries to test the swapping at the moment.  The meter readings indicated charging.
3. The trick with soft iron rod for the collector coils worked.  We are now confident that we can produce a prototype that can generate more than 1 watt, requires two 12 volt batteries or four 6 volt batteries, weighs less than 20 kg and will run as long as the component life â€" estimated to be at least 5 years.  The batteries will be swapped and recharged by the Lead-Out Energy Machine.
4. We need to do more work on the loopback.  We may need to put in diodes to force loopback.
5. The use of magnets at the end of the rod worked on the small prototype but not no the big wheel.  This may be due to the different magnets and coils.  More work is needed.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
ltseung888
Meeting the environmental goal
Will Lead-Out Energy Machines help to solve the problem?
