Paul-R
Quote from: ltseung888 on December 15, 2009, 11:47:25 PM
Who cares about feedback or verification?
Those who wish to improve and develop.
Top Gun
Quote from: Paul-R on December 15, 2009, 06:57:52 PM
...but we also need a set of engineering drawings and a flow
chart describing the logic. Then replications can be attempted,
and results fed back to you.
The logic is as follows:
1.   When Input Power switch is turned on, the 12V battery will start the action of the Proximity Switch PS.
2.   A slight start-up rotation may be necessary if the wheel happens to stop at a “dead” position.  In most cases, the wheel will start by itself as the PS in its ON state will sent a pulse to the Drive Coils.
3.   The PS will be turned on and off depending on whether a magnet approaches or leaves its proximity.  This action controls the current that will pass through the SSR Relay.  The result is that Pulse Current is passed through the Drive Coils.
4.   The stationary Drive Coils will repel the rotating magnets during the Pulse.  This action is similar to “pushing a pendulum” that leads out gravitational energy.  In this case, the action leads-out magnetic or electron motion energy.  The magnetic field is supplied by both the rotating magnets and the Coils.  The direction is not purely vertical.
5.   Thus the real total Input Energy entering the wheel is the Pulse Energy PLUS the Lead-Out Electron Motion Energy.
6.   When the Pulse pauses at the Drive Coil, the Drive Coil acts like a Collector Coil.  In the Input Voltage Waveform, we can see a DC Component and an AC Component.  The DC Component is from the Pulse, the AC Component is from the induced current when the Drive Coil acts as a Collector Coil.
7.   In our particular prototype, we do not use this AC component.  Our DC Voltmeter taking the RMS voltage will ignore it (or let the positive side and negative side cancel out).
8.   The wheel starts to rotate faster and faster.  It will come to a steady rotational speed when the torque balances that from friction and air resistance.
9.   After the wheel has reached a steady rotational speed, Output energy can be drawn out from either the axle or from the Collector Coils.  In our case, we use the Collector Coils only.
10.   The Input Power from the 10 Drive Coils is compared with the Output Power from the 5 Collector Coils after the Output was rectified to DC.
11.   The result was the expected overunity.  The ratio of Output Power over Input Power can be greater than 3.
12.   This ratio of 3 is good because some energy is lost in the form of noise, heat and overcoming air resistance.  This ratio can be tuned with different number of Drive Coils, Collector Coils, positioning of the Proximity Switch or the value of the external load.
I hope the logic is crystal clear now.  It is the Lead-Out Electron Motion Energy that provides the overunity result.  Once Mr. Tseung concludes the deal with the factories and retailers, you will have an overunity educational product to purchase.  There is no need for you to build your own wheel, precision drill the holes, wind the coils, etc.  All you need to do is check for overunity before you buy the unit; adjust the number of Drive and Collector Coils, and vary the Load.  You can then disassemble and reassemble the unit.
The average student is likely to stop at this stage.  You may want to do more development such as loopback, use of soft iron rod as core for the Coils, replace the coils or magnets etc.  You may want to change the sensing mechanism from the PS to laser control.  You may even want to add PLC control.  There will be competition to see who can produce a 5KW electricity generator first.  Can you beat Mr. Tong Po Chi who lost his garage shop; worked on the project at his spare time; had no formal electrical engineering training and has little financial support?
Have fun and share your findings to benefit the World.
markdansie
Quote from: Paul-R on December 15, 2009, 03:57:09 PM
This is one watt overunity more than you have ever developed.
And if you had ever got off your lazy backside and bought a SSG kit,
I wouldn't be able to taunt you thus.
You are correct, I have not been able to build a 1watt unit......but in my defence nor has anyone else. I am happy to be corrected or proved wrong but can you put me in touch with anyone that has?
PS Even Steorn hasnt got one.
Kind Regards
mark
Top Gun
Replacing the Proximity Switch with light control
The Proximity Switch works at low rotational speeds and can be used to demonstrate overunity on the Tong Prototype.  Let me outline the advantages of the light control technology.
There are three light control units.
1.   To turn the Relay on so that DC current will be passed to the Drive Coils.
2.   To turn the Relay off so that DC current will stop.
3.   To sense the rotational speed.  If the speed is too high, turn off the DC current completely.  If the speed is too low, turn the DC current back on.
Such an arrangement will allow a range of speed of rotation.  Later, we can program that with the external load.  At this stage, it is a matter of gathering useful data.  Kenneth has developed a primitive prototype to demonstrate on Dec 18.  It is nice to have other top guns involved.
Paul-R
Quote from: markdansie on December 16, 2009, 05:13:10 PM
Wrong.
Do your homework.
