0 Members and 28 Guests are viewing this topic.
Paul-R
Quote from: Top Gun on December 16, 2009, 11:23:01 PM
Replacing the Proximity Switch with light control
Let me outline the advantages of the light control technology.
Are you using a cadmium sulphide cell (with LED)? Would a hall effect
item do it?
Top Gun
Quote from: Paul-R on December 17, 2009, 12:02:44 PM
item do it?
Dr. Liang in China claimed to have used Hall Effect ICs to build a car that can run on level road without any fuel.
The technique is to use two types of ICs.  One is placed on a stationary cylinder.  The other is placed on a rotating cylinder.
Many hundreds of such ICs are used.  The repulsion force produced will drive the central axle.  The claim is that over 188 HP was produced.
In principle, this technique should work as it can lead-out gravitational energy.  However the car could not climb up steep hills as the gravitational effect diminishes quickly with the angle of tilt.
The Tseung prototype is better in this aspect as lead-out electron motion energy is used.
Top Gun
Improving the Tseung prototype
1. Use laser or other light control devices instead of the proximity switch.
2. Vary the supplied Input Power in accordance with the external Load.  Program control is best but detailed data must be gathered first before meaningful programming can start.
3. The current and power through the relay should be increased by many orders of magnitude.  At present the PS can only take 24 Volts DC.
4. The loopback mechanism must be perfected.  There are two ways.  One is loopback to same wheel.  The other is to use the Output of one wheel for the Input of anther.
5. Encourage more positive feedbacks by selling the Educational Products as soon as possible.
chrisC
Quote from: Top Gun on December 17, 2009, 10:41:35 PM
Hey Top Dork:
Looks like no one is interested in what you and your mirror image, old Tseung has to say. You've been preaching the same old boring stuff and until now, still has zip to show for!
That should put some reality into your thick skull?
cheers
chrisC
