shruggedatlas
Quote from: ltseung888 on October 10, 2007, 01:11:17 AM
[My simple answer is NO.  NO. NO, NO and NO.
The reasons are:
(1)   To Impart energy to a swing and to Lead Out gravitational energy, we must allow the String of the Pendulum to move/swing and gradually increase its tension.  During this gradual increase, the Law of Parallelogram of Forces can be applied.  It is the application of this Law that Leads Out gravitational energy.  No energy should be wasted on collision sound or deformation of the sand or similar material inside the punch bag.
(2)   In punching the punch bag, the force is applied quickly.  The rate of change of momentum is intended to be as fast as possible.  (In Physics terminology: Force is the rate of change of Momentum.)  We want the punch to exert the maximum force on the opponent! The sand or similar material in the bunch bag will deform to absorb the energy.  The best punch is that the String barely moved.
(3)   If the punch is very slow - to become a push, the String of the Punch bag will move.  The Punch bag system then simulates a Pendulum.  (Pushing a person is very different from punching a person.)
That's interesting, because in the go-here forum, you say:
How to Pulse:
One example is the Adam flow nemo?s Pulse Motor described on this same section of this forum. It uses the term Drive Coil to indicate that Current is passed to the Coil to change it to have Electromagnetic Properties. The central disc has permanent magnets and the interaction of the Drive Coil and the permanent magnets will cause rotation of the disc.
It uses the term Pickup Coil to indicate that electricity can be induced when the inner disc with permanent magnets rotates.
The Drive Coil and the Pickup Coil can be the same coil. (e.g. Newman motor) They can be different. (e.g. 225 HP Pulse Motor).
There can be different arrangement of the Magnetic Field. The Adam flow nemo?s Pulse Motor using disc with permanent magnets inside and small coils on the outside facing each other. The Newman Motor has rotating permanent Magnets totally inside one large Coil.
The Adam flow Nemo?s Pulse Motor can rotate upto 4,000 rpm. If two Drive Coils pulse to rotate the disc, the number of pulses per minute is effectively 8,000.
You you seem to think that 8000 pulses per minute (with each pulse being 1/133 of a second) is a way to lead out energy.  How is a pulse that is 1/133 of a second in duration any different from a punch?
ltseung888
Quote from: Freezer on October 10, 2007, 09:18:32 AM
The U.S. military has been working of UFO technology since the 1940's.  Most of which was started by Hitlers scientists.
Nasa provides us with great UFO videos, you should have a look at the film "The Case for NASA ufos," on google.
Some clips -
This one slows down.
http://www.youtube.com/watch?v=5pawTzpNKW4
You can see these pulsing in a fibonacci curve wave pattern.
http://www.youtube.com/watch?v=Ox6BtwDmm3c
This one appears from thin air. :D
http://www.youtube.com/watch?v=lBA7zaB9ZKw
Ralph Ring and Otis Carr built a flying saucer decades ago, piloted by thought and brainwaves.
Interview with Ring -
http://video.google.com/videoplay?docid=8949307179416464163&q=project+camelot&total=69&start=0&num=10&so=0&type=search&plindex=7
Dear Freezer,
I enjoyed the interview with Ralph Ring video.  It took over an hour.  There were not much technical data but I am not worried.  I believe the Lee-Tseung theory and knowledge of the working 225 HP Pulse Motor will get us there.
It confirmed that someone in USA worked on the Flying Saucer with some success.  The USA Military wanted to keep it a secret.  It explained why some posts here were scientific junk trying to discourage work in this area.
The good thing is that China now knows how to build the Flying Saucer.  In my case, it started with a 13 year old girl, Ms. Wini Woo.  All she did was to point out to me that the effective gravitational constant can be zero or negative.  The change in effective gravitational constant can be demonstrated easily with the Ms. Forever Yuen experiment.  I have already outlined the theory.  It is a matter of who will build it for the benefit of the World.  (The top-secret research establishments have already build it.)
Lawrence Tseung
The Ralph Ring Video confirmed and Lead Out the fact that the USA Government already know how to build the Flying Saucer.  We are only playing the catch-up.
ltseung888
Quote from: shruggedatlas on October 10, 2007, 10:21:16 AM
Punch = pass energy to another object.  May even damage it.
Pulse (Lee-Tseung) = pass and lead out energy into same system.  Make sure no harm is done.
hansvonlieven
G'day all,
The idea of driving a motor with pulses is nothing new, in fact it is common technology. With the popularisation of electric hand drills in the 1960's there was a demand to have a drill with variable speeds as the mechanical gear boxes allowed only for two speeds, any attempt to add more gears resulted in an unwieldy device that became quite useless because of its weight and dimensions.
Before I get into how it was done in the end I better explain how these drills work, for those of you that are unfamiliar with the technology.
An electric hand drill has an AC/DC motor that drives it. As such it employs brushes, anchor windings and so forth, unlike pure AC motors which do not have brushes but rely on the 50 or 60 Hz phase supplied by the grid. AC/DC motors were chosen because of their superior torque.
At first it was tried to add a rheostat into the circuit, which slowed the motor down alright, but decreased the torque to such an extend that the drill was next to useless except for some applications that did not require high torque or large speed variations such as dental drills and sewing machines.
In the 1970's someone had a smart idea, which was soon taken up by industry and is now standard. Instead of choking the current into the machine with a resistor, pulses were fed into the motor instead. Developments in the semiconductor industry allowed for a circuit that could feed the full power of the battery or grid into the motor in short, variable bursts instead. Although there was a decrease in speed, the torque remained largely intact.
No-one has ever reported any gain in ENERGY with these device.
Hans von Lieven
shruggedatlas
Quote from: ltseung888 on October 10, 2007, 02:43:48 PM
You are using circular reasoning.  I am asking you what are the characteristics of a pulse that leads out energy.  You are saying in essence is that a pulse that leads out energy is a pulse that passes and leads out energy.
Damage is merely a factor of how strong the objects are relatively.  In the desk toy example, one pendulum does not damage the other.   The impact is brief, similar to the 1/133 of a second in the example you bring up, so I fail to see the difference.
