0 Members and 53 Guests are viewing this topic.
ltseung888
Shapes of the Input Voltage, Current and Power
I shall post the shapes of the Input Voltage, Current and Power waveforms with different setting of the Proximity Switch here.
You are welcome to comment and add your interpetations.
My interpetation is that there is a DC component due to the Pulse PLUS an AC component due to the Drive Coil acting as Collector Coil (induced or referred to as Back Electromagnetic Force BEMF by some).
ltseung888
Power as measure from Position A and Position B
Virtually identical.
ltseung888
Compare Input Energy with Output Energy in 1 cycle
Scope used did not have the area calculation function.  Will get the better (and much more expensive) scope to repeat experiment.
Also improve the efficiency with flywheel first.  Repeat after improvement.
The manual area counting technique is only an approximation.  Do not use that figure as Gospel.  Wait for more accurate measurements.  Different people got different results (COP from 1.11 to 1.20).  I got 1.14.
There is still discussion on whether we should take the sharp peak away from Input and add it to Output.  That would improve COP to 1.8.
ltseung888
Area Comparison
We can use the Paint program to turn black backgound into white.
We can also resize the waveforms so that they represent same units so that we can compare correctly.
We can enlarge the bitmap picture to compare up to the individual pixels.
We shall show this technique when all problems have been smoothed out.  Or we can use the better scope which could do all that for us!
ltseung888
What is involved in the 300 watt prototype?
There are different ways to improve the 1 watt prototype to 300 watts.  These ways include:
1.   Replace the proximity switch with light or laser control devices.  This solution will be tested shortly.  This will allow more accurate timing, faster rotational speed and ease of programming later on.
2.   Adding a suitable flywheel to lead out additional gravitational energy.  This is a very easy  engineering solution.  It will be tried as soon as Tong gets his new place ready.
3.   Loopback.  There can be loopback to same wheel or use the output of one as the input to another.  This solution may need to wait until solution 1 is completed.
4.   Larger Wheel.  We shall let some other team work on this.  The wheels can use spokes to allow for much larger effective diameters.
5.   Use energy from the shaft.  We do not need to worry about the number of Collector Coils.
6.   Use of soft iron rods in the core of Collector Coils.  This also appears to be a simple solution.
When we already have an overunity device verified and shown to thousands, the pressure is off.  It is just a matter of improvement now.  (Once the light bulb can shine for 10 seconds, it can be improved to last for minutes and hours,)
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
