ltseung888
Quote from: Paul-R on January 04, 2010, 12:32:16 PM
You have a shaft driven by an oscillating source with a flywheel.
This can be a problem for designers of ships' prop shafts and propellors
if the motors behave oddly.
You need to take into account the MECHANICAL resonance of this system,
and drive it under conditions which either minimises or maximises the effect
of the oscillating shaft and flywheel. (I am not sure which).
Paul-R
We do not intend for our device to be directly connected to mechanical systems.  It is too difficult to tune for 'resonance' with external systems.  The most likely scenario is to have our Wheel as an electricity generator.  The mechanical systems can then run on the electricity we provide.  Wait until we have the 5KW electricity generator.
Paul-R
Quote from: ltseung888 on January 04, 2010, 08:48:56 PM
We do not intend for our device to be directly connected to mechanical systems...
With the flywheel in position, you have done just that.
The mechanical resonance issue could be why the results of fitting different flywheels are somewhat erratic.
Paul-R.
ltseung888
http://altenergy2012.blogspot.com/
Looks like this group is better funded and organized than most.
ltseung888
Objecting the Steorn Orbo?
People object to devices such as the Steorn Orbo because they thought that such devices violate the Law of Conservation of Energy.  They did not understand (or have not learned) that gravitational and electron motion energy can be lead-out (or bring-in) from the surrounding environment.
They can learn from this thread or via a google search on “lead-out energy”.  If they are in Hong Kong, they can see the actual demo machine.   That Tong Po Chi Lead-Out energy machine is now at the Office of Dr. James Wong, the chairman of the Institute of Energy of Hong Kong.  He and his team will do more checking of the experimental results.
One good scientific point brought out by Kenneth Chong is that the best way to get good quantitative results for pulse energy is via the area under the Power Curve using the oscilloscope.   However, that gave rise to the heated debate on whether we could separate out the DC and AC components of the Curve.  The DC component is the supplied power.  The AC component is due to the Drive Coil acting as Collector Coil.  Such an analysis is not commonly done in the academic circles.
I expect the same discussion will be applied to the Steorn Orbo when they analyze the Input and Output Power waveforms further down the road.
The best strategy is to increase the efficiency and the actual output of the device â€" generating 5KW will be best.  Let us see which team will achieve that and openly demonstrate to the World first.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
chrisC
Quote from: ltseung888 on January 09, 2010, 05:08:11 PM
@Lawrence:
Still trying so hard to 'piggy back' on Steorn's publicity? Well, don't be so sure.
After showing off this Orbo contraption to the world via LiveStream, for a couple of days, it's suddenly 'withdrawn' to being 'privately viewed!
Well, I don't know about you old Tseung. If this Orbo stuff is real and charging the battery with 3X excess power, this battery can go on forever, don't you think so? So, why the 'private' viewing. My simple brain tells me there is no excess power and therefore the battery died and the rest is just a cover up. Sounds familiar to you, doesn't it? After all, you've working on your crappy theory forever and still has nothing to show.
I wouldn't jump on the Steorn bandwagon so quickly. It really won't save your skin. You need to take a community college course in Physics first.
cheers
chrisC
