ltseung888
Potential Interview Questions
2.  How does it work?
The Tong Wheel has the following:
a.   A 60 cm diameter rotor with 16 rectangular magnets at the rim.
b.   15 Coils that can be Drive Coils or Collector Coils.
c.   A Proximity Switch to sense the position of the magnets relative to the coils.  DC current will be sent to the Coils after a magnet has just passed the center of the Coil.  The DC current will let the Drive Coil act as a magnet temporarily.  The Magnetic Repulsion will provide the Pulse Force.
d.   The DC current is stopped as soon as the repulsion has taken place.  The Drive Coils are air coils so that no magnetic pole properties remain.  Step c will be repeated.
e.   Both gravitational and electron motion energy will be lead-out by the Pulsing Force.  The lead-out energy can be greater than 50% as calculated by the pulled pendulum.  This is because the magnetic field is not just vertical.
f.   The reason for the relative large size of the wheel (60 cm) is because the Pulse Force takes time to impart and lead-out the energy into the system.
g.   At fast rotations, the Proximity Switch fails to function.  This actually acted in our favor because that allowed time for the Pulse Force to complete its energy imparting work.
h.   The Supplied Energy is measured from the DC Voltage and Current across the Drive Coils which were connected in parallel.
i.   The Output Energy is measured from the rectified DC Voltage and Current across the Collectors which were connected in series.
j.   One of the tuning parameters is the number of Drive Coils verse the Collector Coils.  Overunity was achieved with 10 Drive Coils and 5 Collector Coils when the load was 1 3 watt lamp or 47 ohms.  We stopped the tuning as soon as overunity can be demonstrated.
k.   A 12 Volt battery was used as the starting source and Pulse supplying agent.
The Demonstration machine clearly showed that the Output DC Electrical Energy is greater than the Supplied Input DC Electrical Energy from the inexpensive Voltmeters and Amp meters.  Some Input DC Energy was also used to overcoming the friction and air resistance.  The extra energy is NOT created.  The extra energy was lead-out from the Pulsing at the appropriate frequency.
The Steorn Orbo and the Bedini Wheel should work on the same principle to lead-out energy.  However, the standard Bedini circult focused on high speed rotation.  That shortened the time for the Pulse Force to lead-out the energy totally.  It was like pushing the swing at the wrong frequency.  The Bedini motor managed to recharge batteries but could not demonstrate overunity.  Hopefully, the Steorn Orbo can do better.
If they use laser or infrared technology,  the trick is to skip Pulsing when the rotation reaches a given speed.  This speed is load dependent and should best be calibrated with the use of the oscilloscope.
Top Gun
Quote from: vonwolf on January 15, 2010, 02:42:17 AM
       ltseung888 Please:
   Stop trying to connect yourself to other groups (steorn's Orbo) that are claiming some sort of OU you had noting to do with their there there work.
    You Even tried to take credit for the A pendulum video, Stephen was just trying to piont out Their possibly for PM. And you jump in and say "look more Prof of Lead Out A" you dont even know if its real. That thing could have batteries all over the place. who would know?
    Please just work on your own projects so far its you still have a long way to go
  Thanks Pete
Dear Pete,
It is not a matter of taking credit.  For Mr. Tseung to claim that the Lee-Tseung Lead-Out theory is correct and universal, he has to apply it to all known OU devices.  It is like Newton’s Laws of Motion. The Laws must be tested on all known cases or circumstances.  A scientist must apply them in all mechanical systems.
Similarly, Mr. Tseung must apply his Lead-Out Energy Theory to Newman, Bedini, Grey, Chase Campbell, Steorn, 225 HP Pulse Motor, TsingHua Magnifier, Liang, Wang electricity generators etc. etc.
Mr. Tseung is promoting the Lead-Out Energy Theory.  He is NOT promoting the Tong Wheel!  The Tong Wheel is just one implementation.  Mr. Tseung is opening the doors for hundreds or thousands of OU device inventors.  Law of Conservation of Energy will no longer be a roadblock.
If the Lead-Out theory is correct, the standard Bedini motors must be modified in the following ways to show overunity.  The rotational speed must be slowed down for the lead-out energy to take effect.  The wheel must be large enough to allow that to happen.  If one of the Bedini followers modified his Bedini Prototype and achieved OU, the World will benefit from the Lead-Out Energy theory.
Mr. Tseung has already achieved overunity with the Tong wheel.  He is challenging the World to test it out at the Radio Stadio.  You or your friend in Hong Kong can take that challenge.  He was the first one to enroll in the 1 watt overunity.com competition.  Stefan will receive one of the early units.  (The present high priority is Beijing - not this forum.)
ltseung888
3.  How long have you been working on it?
If we consider the earliest time when the swinging punch bag hit me, that was over 50 years ago.  The later time was in 2000 when I did the research on Energy from Still Air.  The time when we really focused on Lead-Out Energy was December 2004.
The first person who thought that Energy could  be Lead-Out from the Pulled Pendulum was Lee Cheung Kin.  He woke me up from the Hotel early in the morning and we worked out the mathematics.  The moment we realized that the gravitational energy lead-out is equal to the vertical component of the tension of the string times the vertical displacement, we knew that we hit the jackpot.
We were 100% certain that gravitational and electron motion could be Lead-Out.  Since both Lee and I are theoreticians, we did not build any prototype initially.  We searched the Internet for OU device patents and descriptions.  The examples from China include Liang, Song, Wang.  The examples from outside China include Newman, Bedini, Gray and Bessler.  The first forum I joined was the Bessler.com.  I posted the Lead-Out theory and said that the mystery of the Bessler Wheel was solved.  They banned me.
I then started to find someone to build the prototypes.  They include the following:
(1)   An Engineer who bought a car wheel and tried to rotate it with small refrigerator magnets.
(2)   A bicycle repair shop person who gave up after a few weeks
(3)   A team of engineers who tried to do a combined motor and generator.
(4)   An electrician who owned a transformer repair shop.  He tried to do a pulse motor
(5)   Mr. Sun and team who helped to build many gravity wheels â€" the best rotated for 3 hours in my living room late at night.
(6)   The many failed attempts such as helicopter in a box, car in a box etc.
(7)   The team of students who did not have the experience.
The luck came when I met Tong Po Chi in late 2008.  He started on the jumping tube; the single coil pulsing wheel with 4 magnets; the four coil and eight magnet pulsing wheel and finally the 60 cm Tong Po Chi Lead-Out Energy Wheel.  Tong stopped tuning as soon as the wheel could demonstrate overunity.  Much more can be done.
chrisC
Quote from: Top Gun on January 15, 2010, 07:08:32 AM
Dear Pete,
Er, Mr. Tseung is a scientist? Well, then you really are Top Dork!
cheers
chrisC
ltseung888
4.  Is it available to demonstrate?
Yes.  The Tong Wheel was demonstrated in two Open Shows in Hong Kong.  The First Show was the Innocarnival 09 event in the Hong Kong Science Park in November 2009.  The Second Show was the Inno Design Tech Expo in the Hong Kong Convention Center in December 2009.  Over 25,000 visitors saw our Tong Wheel.
We have now placed the Tong Wheel at the Studio of the Better Hong Kong Radio Show.  Miss Forever Yuen was hired as a part-time helper in one of their projects.  They now have the capability to demonstrate the Wheel to any qualified person at short notice.  Guests are welcome to bring their own measuring instruments.  They are also welcome to bring cameras and take pictures or videos.
This Open Show policy is likely to continue.  We shall replace the 60 cm Tong Wheel that can only generate 2-3 watts with the better units as soon as they are ready.  The General Public will be able to see not just the recordings but also the latest real device.
