ltseung888
11. What improvements do you expect to make to the technology?
Improvement 4
Battery A, Swap and no Battery.
One objection from the average layman  who does not read meters is â€" your wheel runs on the 12 V battery.  It is not overunity.  If you do not need a battery to run, then you get more credibility.  Initially, I ignored them.  But I raised the issue with our team.  They believed that it could be done.
The first step is to check the recharging of batteries.  We can put a used 12 V battery at the Output and recharge it similar to the Bedini demonstration.  We found that the recharging current from the Tong wheel is not sufficient to fully recharge a 12V battery but strong enough to recharge two 6 volt batteries separately.  The thought at the moment is to increase the Output with the 3 Improvements discussed above before trying the recharging again.
The second step is to do the auto-swap of the two batteries.  The circuit and board has been designed and built.  The swap time can be from 1 second to 17 minutes.  We could use the tiny 12 V batteries to show the results quickly.  There is also the manual override allowing us to select either Battery A or Battery B as the Input Battery.   The basic circuit has been tried and will be fully tested after the improvements.
The last step is to take away the Battery totally.  The Wheel will be started via hand rotation.  The Output will generate enough electricity to drive the Wheel.  Some electrical components such capacitors need to be added.  If this can be done, the demonstration will be even more convincing to the average layman.
(to be continued)
ltseung888
Improvement 5
Compare with the Steorn Orbo mechanism.
The A wheel uses magnetic repulsion to lead-out gravitational and electron motion energy.  The Steron Orbo uses magnetic attraction to lead-out gravitational and electron motion energy.  The theory is the same but the technical mechanisms are different.
Another wheel will be built with credit to Steorn.  We shall be in a position to compare efficiency, cost, difficulty in engineering etc.  This is an excellent opportunity to show that the Lead-Out Energy Theory is universally applicable.  Two wheels working side-by-side will be impressive.
This improvement will be done after Steorn has disclosed their technology fully.  The only changes we need are the toroidal windings.  The other components are already available.  Our large wheel size and more magnets and coils should generate much larger Output Power than the being demonstrated Orbo.
(to be continued)
chrisC
Quote from: ltseung888 on January 16, 2010, 04:44:52 AM
Potential Interview Questions
....  I believe we have been left alone so far because we can only produce 2-3 watts.
I believe you have been left alone because of your idiotic delusions!
cheers
chrisC
ltseung888
Improvement 6
Program control relating Input to external load
This is likely to be the element that makes the Liang car and the 225 HP Pulse motor better than other similar OU inventions.
We believe that some kind of resonance effect is present in the leading-out of gravitational and electron motion energy.  One example is the addition of flywheels to the Tong Wheel.  Too small or too large a flywheel will decrease instead of increasing the COP.  The simple layman explanation is that one should only push the swing at the right time for the magnitude to increase.
With program control, we can adjust the Input in accordance with the External Load.  However, we need to gather enough data first.  This improvement will be added later after we have done sufficient data gathering.
(to be continued)
ltseung888
Improvement 7
Narrowing the gap between the magnet and the coil
We know from the Laws of Physics that the magnetic force varies with 1/(the square of the distance)
This means we should reduce the distance between the magnets and the Coils.  The Tong Wheel cannot safely do that because of the engineering difficulties.  There will be the slight vibrations.
A better approach is to enclose the rotating magnets inside a fixed cylinder.  The coils can then be physically attached to the outer surface of the fixed cylinder.  The physical distance of separation is the thickness of the cylinder wall.  This arrangement allows the magnets and the coils to be set up with different angles for the best effect.
The 225 HP Pulse Motor uses this arrangement.  We shall test this configuration before mass production.  It will simplify the tuning.  We may even try some type of lubrication.
(to be continued)
