Forever
In the diagram, we use balanced rotation. Three pulse points are shown. The application of the pulse is tangential to the direction of rotation (clockwise in this case).
It is possible to always to apply one single pulse to the many points on the rotating cylinder. However, multiple pulse points effectively increases the pulse force amplitude.  ;D
Forever
We can apply electromagnetic repulsion to try to generate the ideal pulse force. For example, the permanent magnets are inside the rotating cylinder with the North Pole facing outwards. The coils on the outer cylinder are pulsed with the North Pole pointing inwards. The current to the pulse coil is in one single direction but may be on or off. Thus, the coil will show strong or no North Pole properties.
The pulsing frequency is timed as follow:
1. The permanent magnet is slightly on the RHS of the coil. The current to the coil is on.
2. After the repulsion pushes the permanent magnet and hence the rotating cylinder to a mid way position(with another permanent magnet), the current to the coil is turned off.
3. After the next permanent magnet is at position 1, the current to the coil is again turned on.
4. Effectively we are repeating 1 and 2. Thus, the frequency of the current must be correct. In addition, the pulsing will tend to accelerate the rotation. Therefore, a program is required to adjust the frequency or the pulsing current strength.
5. This is what we mean by adjusting the input according to the output load. Most of the overunity developers have not done this( Newman, Bedini, Adams etc.)
;D ;D ;D ;D
gaby de wilde
Quote from: Forever on October 27, 2007, 03:33:03 AM
Using multiple pulses takes a lot of stress off the bearings. I'm trying to make it spin suspended in the air, the wheel first tends to float in all directions. Above a not-given(haha) number of rpm's it can stand on a pin. Beyond that there is even a point where the wheel doesn't stand on anything anymore. It's just levitating between the coils. This is not a useful machine jet but it already shows that (mindless?) acceleration and deceleration leads out a lot of bearing friction.
I will let you in on a little secret. The direction of the pulse should be almost straight towards the axle. It should also have some spring like storage. The pulse can then oppose the centrifugal forces and lead out it's power over a range of degrees rather then over a small angle of rotation.
Now for the flux:
Say the wheel has north poles facing outwards. The pulse coils have a ferromagnetic core.
Now we place an additional north pole BEHIND the coil.
The purpose of this magnet is to induct a bit of flux into the core.
The flux inducted into the core should not be enough to repel the rotor magnets by a very small bit.
The rotor magnet should also be able to induct it's field into the core.
We now have 2 opposing fields inducted into the core.
A slight pulse will be enough to generate FULL repulsion in this configuration.
But if you really want godly powers out of the machine then you make this happen by utilising back emf alone.
So the stator coil attracts the rotor magnet.
Then the flux collapses in the coil.
Now we get FULL repulsion at no cost of any kind.
Now I'm going back to my 100% permanent magnet designs. *hahaha*
Quote from: Forever on October 27, 2007, 03:55:39 AM
But the rotoverter researchers have addressed this topic. :)
http://www.google.com/search?q=rotoverter
blog  | papers | tech | inventors  | video
ltseung888
Quote from: gaby de wilde on October 27, 2007, 04:20:55 AM
Using multiple pulses takes a lot of stress off the bearings. ...
Now for the flux:
Gaby,
This post is very high quality.  The suggestions will be carefully considered.
Regards,
Lawrence
ltseung888
Quote from: Freezer on October 27, 2007, 12:55:49 AM
Scroll the video to 1:39:00
He shows some pulse devices that might relate.
http://video.google.com/videoplay?docid=2858148671911962750&q=energy+from+the++vaccum&total=137&start=0&num=10&so=0&type=search&plindex=2
Dear Freezer,
Thank you for the tip in scrolling to 1:39.  Bedini did have a device with coils and permanent magnets arranged in a way that could lead out gravitational and electron motion energy.  Like Joseph Newman, he also discovered that "seemingly dead batteries" could be recharged with "back EMF".  He was able to produce many prototypes that could demostrate over unity.
If he and Tom Bearden knew the Lee-Tseung Lead Out theory then, he could have:
(1) Overcome the objection or roadblock of CoE
(2) Added the program to adjust the Input Pulse with External Load
(3) Drawn electrical or mechanical energy out directly
In other words, he could have produced a slice of the 225 HP device.  He might also have observed the Flying Saucer effect.  (He has rotating magnets.)  I have emailed the Lee-Tseung theory to him/his supporters.  We may be able to produce a win-win scenario.
Lawrence Tseung
Good development work leads out email and theory support from the old Tseung
