0 Members and 68 Guests are viewing this topic.
ltseung888
To: ltseung@hotmail.com
Subject: DoD JTF
Hi Lawrence,
I have been assigned to an energy Joint Task Force that meets every other month to review various technologies for funding/implementation.
As a member of this JTF, I have a say in which techs are recommended for funding.
Please reply with that best tech you know of that can be demo'd and would allow me to present the tech to the other members of the JTF.
Thanks,
XXX
Do you believe in the existence of XXX?
There is no harm in providing him with information to benefit the World.
chrisC
Quote from: ltseung888 on December 11, 2007, 03:04:28 AM
Subject: DoD JTF
Hi Lawrence,
Thanks,
XXX
I believe more in magic shows and circus acts more than XXX in JTF created in old Tseung's circular mind!
Dream on Lawrence. Seems like what you do best each day.
cheers
chrisC
ltseung888
My reply to XXX, consultant to DoD (Department of Defense) of USA.
If I were to recommend Cosmic Energy Machine projects to a Government, I would propose the following:
(1)   Energy from Still Air projects.  This is the fastest and easiest to demonstrate.  The material cost for the proof-of-concept experiment is less than USD100.  The apparatus could be built within days.  The implementation diagrams can be seen in http://www.overunity.com forum under he Lee-Tseung Lead Out Theory Thread.  The relevant replies are 640, 845-848.  The particular invention is useful for transporting water to great heights and long distances at a steady rate.
(2)   Energy from Gravity projects.  Chas Campbell reported privately that his flywheel could do the following:
-       Start the Device and allow the flywheel to spin to designed speed with the output generator disconnected.
-          Disconnect the Input Motor.  The flywheel continued to rotate at approximately the same speed.
-          Connect the flywheel to the output generator and a 75-watt light bulb.  The light bulb would be on for long periods.  (Much longer than would be expected from the mechanical energy stored in the flywheel.)
-        This may be a validation of the Leading Out of gravitational energy via an unbalanced wheel as predicted by the Lee-Tseung Theory.
-          If this could be independently confirmed, many devices using the same technique would be possible.
(3)   Energy from Electron Motion projects.  The best example is one slice of the 225 horsepower Pulse Motor project.  That slice could generate over 20 horsepower.  The technology is an improvement over the Newman, Bedini or the Adams Motor.  The improvement is mainly the addition of a program to adjust the input to the external load.  This can be the most practical device.  It should be better than the huge Hungarian EBM machines.
(4)   Flying Saucer Projects.  The basic theory is similar to the letting go of the chained ball.  In this case, the force holding the ?spinning ball? is likely to be magnetic in nature.  At the appropriate time, the magnetic force would be cut.  The spinning or rotating ball would carry the entire apparatus in the tangential direction.
(5)   The Flux Change Projects.  According to Lee Cheung Kin who went to Japan for this particular purpose, the Japanese Company is gearing up for production already.
I personally would recommend an International Cooperation Effort on this new field of Cosmic Energy Machines.  This new field will not be limited to one or two inventions.  Hundreds if not thousands of devices using Energy from Still Air, Gravitational and Electron Motion Energy will emerge in the near future.  The future of the entire Human Race will be affected.
Regards,
Lawrence Tseung
ltseung888
Getting a one-page summary for Wang et al.
Oops.  Not ready.
Koen1
Hahahahahaha :D Your comedy show is getting funnier and funnier by the day!
So you are in contact with agent XXX from the DOD? And you accuse US of being CIA agents? Tsk Tsk!
Are you sure it was agent XXX from the DOD?
Or was it agent Dud from the XXX?
Come on man, you can't believe this yourself...
You expect us to believe that the Chinese government would allow you to hand a revolutionary free energy solution over to the U.S. Defense Department, and would not classify and/or build it for own use immediately? I mean, ignoring the fact that all these government agencies probably find it just as nonsensical as the majority of your audience here does, of course.
At risk of being flooded with yet more nonsense, I would like to leave your nonsense about the water pump experiment and the pendulum observations aside for now, and would like to hear eactly how you propose to extract electricity directly from gravity. And I do mean hear how you propose to do it exactly, not some list of possible ideas that don't acutally amount to an experiment, like you have done before.
