0 Members and 70 Guests are viewing this topic.
ltseung888
Dear Keon1,
I would like to settle one issue after another.  In Physics or Mathematics, sometimes when you do not understand one section, you will not be able to follow the next section.  This is why some students find Physics and Mathematics difficult.  (For example, if you do not understand addition, you will not be able to follow multiplication).
In the case of delivering air+water to a great height with an air pump and one-way valves, a physicist must be totally satisfied that the experiment is absolutely correct and verifiable because of its implications.  Hans says that it is a hoax or fraud without replicating the experiment.
The challenge to the Forum Members is for some of you to actually do the experiment.  You do not need to send water to the 34th floor.  Sending to the 4th floor will be enough proof-of-concept.
Without absolute confidence in the experimental result, further discussion will be pointless and more confusing.  I shall explain the implication in a separate post.
Lawrence Tseung
Absolute confidence in the experimental result is necessary for understanding its profound Physics Implications.
ltseung888
The profound Physics Implications of the air+water air pump experiment.
Let us accept that air+water can indeed be pumped to a greater height as described in 640.  The First Physics Implication is that it will not violate the First Law of Thermodynamics or the Law of Conservation of Energy.  Energy from Still Air is used.  The system is not a closed system.
So far so good.  The next question is that if Energy is extracted from Still Air, what will happen to the resulting temperature?
If we do an additional measurement of temperature at the Input and at the Output, we would find that the temperature at the Output is cooler.  Some experimenter will immediately say that this is expected as the slightly compressed air+water expands.
However, the Second Physics Implication is enormous.  The Second Implication is that when the energy from still air is used, there will be a lowering of temperature.  This means we have a machine that can do Global Cooling.  Heavy use of it will reverse Global Warming.
I shall pause here for you all to comment and understand.  This is also the reason why I recommend it to the Chinese, USA and other Governments of the World.  Global Warming can be reversed!  We can save the World by reversing the Global Warming with Energy from Still Air Machines.
Lawrence Tseung
Understanding the Physics Implications is important before we can save the World.
hansvonlieven
Quote from: ltseung888 on December 11, 2007, 01:51:07 PM
Lawrence Tseung
There is already a very large machine in operation that does precisely that.
Using as an energy input the sun's radiation the water and air are elevated in temperature and a rising air stream carries tiny droplets of water upwards where it strikes a colder layer and loses heat, forming a precipitate that falls down again.
The surface phenomenon is known as evaporation, the precipitate is called rain and the overall process is called weather. The machine is so big it covers the entire globe.
How do you propose to add to this process with a few pipes sticking into the air?
Hans von Lieven
ltseung888
Quote from: hansvonlieven on December 11, 2007, 02:36:17 PM
Hans von Lieven
Dear Hans,
Your thinking is getting closer.  If you imagine the water tank as a dam, the water stored in the dam can power turbines to generate electricity.  The process you described is used to refill the dam.  That is a known way to use ?Free Energy?.
However, not every place on Earth has good sunshine.  The sun does not shine 24 hours a day in a single place all year round.  Thus we need a Cosmic Energy Machine that can generate electricity 24 hours a day, 7 days a week independent of weather.
The air+water air pump theoretically can extract Energy from Still Air and provide Global Cooling.  The simple proof-of-concept experiment points in that direction.  However, it is not efficient.  It needs a high water tower; pipes, one-way valves; strict operating procedures etc.  It is fixed in one location.  Ways such as using air+water jets to power turbines are being researched.
Please try to do the experiment on 640.  Confirmation from you is more convincing than from Forever Yuen.
Regards,
Lawrence
nightlife
ltseung888, are you talking about circulating water from the earth using one way valves to holding tanks and then back to the earth? If so, that could work as long as the water was to come out at a lower level then the water came from causing a siphoning effect.
That makes sense because if you siphon water from a bucket using a tube, the tube can be raised high above the bucket as long as the end is dropped down below the water level. The water would run until the bucket was empty. This concept could be used with rivers both above and below the earths surface as long as the water came from up stream and returned down stream. The flow of water could be used to create power.
Is this what you are talking about?
