Thanks to ALL for your help!!
Marco's Dancing Magnets.... doing the 7.8Hz dance
Started by tao, July 21, 2007, 04:59:04 PM
specter
I've made some experiments with toroidal coil. The only thing that happens - flux leakage. Magnets just attract when current is on. Non-magnetic materials are not affected (coper, aluminium, paper). No changes of mass.
7.8 Hz - is simply a resonant frequency of Marco's setup. Try different magnets (different shapes, sizes, strength) and you will get another resonant frequency.
@tao
If A-field lines outside of toroidal coil where of toroidal shape (see Fig. 8 ) there whould be magnetic field (B-field) outside the coil, because in this case the equation rot(A)=B=0 doesn't stand. rot(A)=0 means that A-vector must be a gradient of some scalar function outside the coil. Only in this case B=0 outside the coil. In case A=grad(f) (which means that B=0) lines of A-field must be uncurled and basicly start somewhere and end somewhere, similar to electrostatic field which starts and ends at charges (remember E=-grad(phi), where 'phi' is electroctatic potential). It's elementary vector analysis.
>> Below I will be showing you an excellent paper by Rick Andersen.
It's not excellent - it's missleading.Ã,  ;)
tao
Quote from: specter on July 24, 2007, 10:09:25 AM
@tao
It's not excellent - it's missleading.  ;)
Look up the Aharonov-Bohm effect and the electron slit experiments specter. It isn't 'It's elementary vector analysis.'
In fact, look up the Telos experiments, read the links that Grumpy posted in his post.
In addition, I HIGHLY doubt that the 7.8Hz frequency is the mechanical resonance frequency for Marco's SPECIFIC SETUP... I will bet ANYTHING that that is NOT THE CASE, in FACT, I KNOW it isn't the case. I have evidence from other researchers I have been talking to and they remark about MUCH STRONGER energy transference effects between magnets around the 7-8 Hz frequency mark.
Sorry to say, but this might just be more complex than you want it to be, no offense...
specter
I'm not offended :)
Firstly Aaronov-Bohm effect is quantum effect described in terms of Schredinger's equation. So it's completly wrong to simply extrapolate it to our (non-quantum) scope. Just google for scientific papers describing effect (not Bearden's!).
tao
Quote from: specter on July 24, 2007, 10:37:15 AM
I'm not offended :)
I do realize this is a quantum effect, and I am not solely quoting Bearden. Bearden 'extrapolates' quite a bit...
The issue is, I have collaborating evidence that in this 7-8 Hz range, a seeming 'transference' (or 'additive effect') of magnetic fields is greater.
I do realize, it will soon become a  'put up or shut up' situation, of which I KNOW. Yet, I need to formulate the best testing setups, so as to alleviate unnecessary $ loss to my person :P ...
turbo
Quote from: rensseak on July 24, 2007, 10:07:50 AM
Hi tao marco and all,
what is also curious with the dancing magnets that they are always swing in opposite direction.
and marco, how did you face the pools of the magnets?
regards
Norbert
well actually in those speaker magnets, one side of the disk is north and one side is south..
the magnets were placed same poles facing each other so that would be on one side n - n  and the other s - s.
so they were repelling each other.
Marco.
