Disclosed: Peter Markovich and his 'essential' A.T.R.E.E.
Started by tao, July 25, 2007, 04:56:27 PM
vince
Hi All;
I was playing around with the
ATREE I had built earlier in this post and to my surprise there might be something to this design after all.  Earlier I had tried many different things to try and get voltage from the device but my meter showed nothing.. Well It turns out my meter was faulty!   When I tried checking the voltage with a new more sensitive meter I was getting a small but constant voltage of 80 to 100 m volts.  I tried putting different capacitors across the two output leads and was able to vary the voltage substantially.  With two 50 volt 22000 uF dc capacitors in parallel I am able to maintain .15 volts .  I has gotten as high as .7volts.  When I attached a 2500 volt ac microwave capacitor to the ATREE I was able to actually get a spark after about 10 minutes of charging.  The output is definitely DC..I tried putting a resistor across th leads after the capacitor and it drained the voltage to 0.  It will slowly build the charge after a while and return to a steady state.  I don't have a low voltage LED to try on it but when I get one I will try it.
I'm not sure how to harvest this voltage but it is definitely acting like a collector.  I know my device is crude but maybe a properly built one will get better results.
I am currently building a RENE- RATER and will post some pictures soon for anyone that is interested.
Super God
>9000
prohexima
Hi vince ,
did you change your configuration i mean the primary coil ;
before you wound insulated copper wire am i wrong?
did you change it with bare copper wire ?
Quote from: vince on January 01, 2008, 10:12:58 PM
Hi All;
vince
NO, I did not change a thing.  The primary is wound with #26 magnet wire just like the original diagram in this posting shows.  The only things that I changed was my meter and the way I attached capacitors to it.
Ariochdm
You might get an additional gain in electricity by moving the wire that connects to the sphere.  Placing it around 19.5 degrees below the equator might yield a gain.  This is based on the hyperdimensional physics model aka Hoagland where signatures of of the aether expressing itself on environment occur on a rotating sphere at 19.5 degrees above and below the equator.  Even though your unit is stationary you might still see something.
http://www.enterprisemission.com/images/hyper/solm1.jpg
