Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
Hi Bob,
Thank you very much for the diagram.  We are excited to see the primaries added.  Also, thank you for the testing of the aforementioned.  I look forward to those results.
@ All
Eldarion tested just one primary on our air core.  Open ended.  Eldarion says, "Something interesting is that this is proof that we can get a offset signal directly out of the toroid--i.e. a signal that is non-symmetric on the vertical axis."
I will ask Eldarion to post the scope shot and details.   ;D  Bob will be the only one not surprised!  LOL  I will just tease, that it produced a little juice!
Bruce
eldarion
Quote from: btentzer on August 11, 2007, 11:47:02 AM@ All
OK, here you go! :)
I was using a small scavenged iron core toroid from a computer power supply.  The windings all overlap, so I can't do much with it at all other than single phase tests like this.  The air core toroid I wound has primary lengths that are too short and too little coupling, as far as I know.  EDIT: You can see the toroid in the background of the middle picture.
I have attached a schematic of the apparatus, as well as the original pictures that I sent to Bruce.
EDIT2: The scope settings are 5V/div vertical, and 200ns/div horizontal.
And here is my original message:
Quote from: eldarion
Bruce,
I have completed construction of the 20ns driver board--attached are a
couple of pics.
Something interesting (and really the reason I am writing you) is that this
The scope shot was taken with only one primary connected to the driver
board, and the output of the toroid was connected across a 22 ohm resistor.
The scope leads were placed across that resistor.
No DC bias or anything interesting was applied.  The driver board consumed
about .138W of power at 500KHz (with a 20ns pulse width), and those peaks in
the scope shot are about 0.4 watts, if my scope is measuring them correctly!
I would say this method shows some promise.  And the best part is, if we're
wrong, then all I have to do is plug the other board back in! :-)
I'm pretty confident we will get some interesting results once a properly wound core is connected to this thing! ;D
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Jdo300
Hi Bob,
Thanks for the updates to the circuit board. I personally am very interested in driving the primaries with one-wire input (since I have done that before with a function generator for a transformer and it works great). I have some questions for you:
1. As for the diagram, do you have any rough recommendations for the circuit component values?
2. I took a look at the driver chips you mentioned. I am going to order some samples myself. They are definitely superior to the ones I am using since they can charge a twice the capacitance mine can in the same time. How would you connect the open ended coil to this? Just tie one lead to the output pin?
@ Eldarion,
Great circuit setup! I was very interested to see that you had one of the primary coil left hanging open! If I get a chance, I'm going to try that out myself. I'm going to be testing two TPU pulsing circuits today to see if anything interesting happens. I'll post a schematic for you all later if I get anything worth looking at.
God Bless,
Jason O
Jdo300
Oh by the way, I'll also be on Skype today (Jdo300) if anyone would like to chat/voice chat.
God Bless,
Jason O
Bob Boyce
Quote from: Earl on August 11, 2007, 11:29:51 AM
Hi Bob,
thanks for your reply.  What you are saying is that not only can three primaries serve in a catalytic action each primary with a wire hanging in the air, connected to nothing, but that the secondary can output appreciable power with one lead hanging in the air, connected to nothing.
Did I understand this correctly?
Regards, Earl
When you have DC bias potential applied to that secondary, it is no longer connected to nothing. It is coupled to the surrounding environment. The higher the bias potential, the larger the bubble of environment it is coupled to. I am hoping that you understand.
Bob
