Eldarion and Bruce's build of Bob's Energy Converter
Started by eldarion, July 27, 2007, 12:58:39 AM
eldarion
Well, here are some pics of my build of Bruce's concept TPU.  Gotta love the "Export to Reality" button in my CAD software!  :D ;)
I hope to fire this baby up next week; the only major item left outstanding is the boost converter for the pulses and the HV bias.
For now, enjoy. :)
P.S. If anyone here wants to have a copy of the FPGA firmware that I wrote to generate the pulses, just let me know. you can get a copy here: http://www.overunity.com/index.php/topic,2894.0.html  I made it so that I can tweak pretty much anything I want to with respect to phase, pulse width, timing, etc.
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Quote from: eldarion on July 27, 2007, 12:58:39 AM
For now, enjoy. :)
P.S. If anyone here wants to have a copy of the FPGA firmware that I wrote to generate the pulses, just let me know.  I made it so that I can tweak pretty much anything I want to with respect to phase, pulse width, timing, etc.
Hi Eldarion,
The coil looks good.  Can't wait to see what happens.  I also can't wait to see that controller of yours at work on the Bob Boyce TPU in the future.
I can't believe I never even asked you what you were using for your controller.  So I take it you can write programs for microprocessors.  You are indeed the man we have been looking for.  That will make designing a proper controller so much easier, from what a couple of the guys have mentioned before to me.
Happy Days!  :)
Bruce
Jdo300
Hey man,
The TPU looks sweeet :-). How big is your controller board? Can is it small enough to fit into your ring? if not you may run into major problems syncing up the controller to the coil once that high speed field forms.
Just a few days ago me and a colleague got the bright idea to see how much of a relativistic effect we could 'predict' from the rotational speed of the TPU. In my case, the fundamental resonant frequency of my coils was about 480 kHz. Now, this is a very bad approximation because we basically converted the angular speed to a linear speed and used a formula from special relativity to calculate the time shift that would result.
I can't remember what the numbers were exactly but it came out to be somewhere in the neighborhood of 276 nanoseconds difference for every one second of time. At first glance, this sounds like no big deal but from an electronics perspective, that would throw off the frequencies by more than a quarter wavelength in my case. I imagine that the effect would probably be a little worse in reality since the field is 'technically' in an accelerated reference frame, so we would have to use general relativity to predict the effects (I'm not even going to go there, lol).
But any who, my point is that if you create a field that can spin at over 30 million RPMs (in my case), there is bound to be some kind of relativistic interactions. So ultimately, we all need to keep our junk in the ring, lol. I'm guessing that wouldn't be to hard with the micro controller if you can make a small board for it to mount on inside the ring.
God Bless,
Jason O
weri812
love the rings
great work
looking foward to see the controller
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
eldarion
It would seem that I forgot to post a pic of the controller.  Here you go! :)
All the wires dangling off of it go to my power supply and scope; they are there only for testing the pulses before I hook it up to the coils.  The board in the back is a delta-sigma ADC; the MOSFET board to the right contains MAX627 MOSFET driver chips and IRF640s.
I'll clean up the source a bit and then post it if you like, but I will warn you: it's all written in Verilog and VB .NET.  This is no ordinary microcontroller! ;)  It's actually an FPGA, meaning that I create logic using a hardware definition language.  I have been programming microcontrollers for the past 5 years or so, but once I got a taste of the power of an FPGA I didn't want to go back. :D
My only concern is that the board is a bit too fat to fit in the center of the coil; I wonder if I can mount it above the coil in the center?  Or up on end in the center?
Eldarion
-- Thomas Paine
