Eldarion and Bruce's build of Bob's Energy Converter
Started by eldarion, July 27, 2007, 12:58:39 AM
eldarion
OK, thanks for clearing that up! ;D
I will remove the suppression network and see what happens!
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Earl
@All
I remind everyone that in my experience, a series damping network consisting of a 1 nF ceramic in series with a ferrite bead soldered directly between drain and source knocks out the overshoot on the back EMF pulse, without effecting the main BEMF pulse itself very much.  Such a lossy-L / C network is fundamentally different from a R/C network, often used.  I achieved fantastic results by choosing the correct bead from a R&D variety designer's kit..
Every scope has a rise time and every scope probe also.  Both have to be fast in order to see narrow spikes that may contain enough energy to destroy a transistor.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
eldarion
Hi Earl,
Thanks for the tip!  Right now, I am just going to let the coils ring as they wish, like Bob said to.
All,
I have removed the suppression network and tried a couple of tests with no load on the output.  With 13.8V in, I can get an 80V p-p sine wave on the output with one end of the secondary tied to ground.  Applying 12VDC "HV" potential to one end of the secondary (the one that was tied to ground earlier) merely shifted the waveform up by the 12VDC, and unfortunately did not increase the p-p magnitude of the signal at all.
So something is still wrong; any ideas? ;D  (My first thought is that the "HV" potential is too low, and I will see if anything changes with 160VDC HV potential).
The waveforms on the primaries are rather interesting, I will post a scope shot later on.
Eldarion
EDIT: I tried it with 160VDC as the HV potential, and unfortunately there was no change.
I am runing all of these tests without the magnetic bias.  It would be really nice to know if the magnetic bias is required to see any effects or not! ;)  (From what I understand, rotating electric fields in a vertical magnetic field cause odd and interesting things?)
-- Thomas Paine
Bruce_TPU
Quote from: eldarion on December 20, 2007, 03:06:48 PM
Hi Eldarion,
I have enjoyed watching your progress on the waveform.
As for what you say above, I say, "fire it up and let 'er rip!"  LOL  Then you will know if there are any effects or not.    ;)  Just make sure that the sky is clear above....
Jdo300
Hi Eldarion!
It has been great watching your progress with your build and I commend you for your tenacity to see this through. I have been moving back to my home town of Toledo for the last few days so I don't yet have any of my lab things unpacked. But I did a few interesting experiments over the break that I will pass along to you later.
As for your question about the magnetic bias, from what I understand, the rotating field is completely useless without it. We need the orthogonal vector to turn the 2D planar field into a 3D vortex field. Thats what the MAGVID people were saying.
God bless,
Jason O
