Eldarion and Bruce's build of Bob's Energy Converter
Started by eldarion, July 27, 2007, 12:58:39 AM
Earl
If you absolutely have to, you could build your own 10:1 probe.
http://zone.ni.com/devzone/cda/ph/p/id/17
shows how - along with the equation R1C1 = R2C2.
One of the caps is a small variable to do frequency compensation while watching a square wave.
It could be that making C1 fixed with C2 variable is more practical.
Searching ebay for 10:1 probe or 10x probe might turn up something?
Regards, Earl
Quote from: eldarion on September 15, 2007, 12:49:38 PM
Hi Earl,
I would post a pic of the gate waveform with a good probe--if I had a good probe! :-[
The best probe that I have is a 1x cheapie.  I am looking into getting some better x10 probes--something that I've put off for far too long!
I assume the gate waveforms are OK because I can scope across the FET output, and when the FET turns on the voltage drops straight down to zero--very little slope from what I can see.  Also, the FETs are stone cold, even at high frequencies.
I know the above observations will not replace good scope measurements, but that's all I can do at the moment...
Eldarion
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
Hello All,
Well, the secondary is wound.  How long did it take?  I lost count!   ;D  Winding it didn't take very long, but "straightning" and "spacing" and "waxing", well, let's just say that it took a while.   ;)
The first picture is of the secondary (16 gauge, teflon coated solid, silverplated wire) taped with #35 electrical tape.  Over this I applied the motor tape.  It wrinkled, but still makes a "solid" surface for the last windings, that of the 6 primaries.  (To be wound with 20 gauge teflon coated, solid, silverplated.  The red wire in picture)
Happy winding to all,
Bruce
(I still have to wrap another core after this one is finished!  My fingers are sore thinking about it.)
Bruce_TPU
Hello All,
I first marked the core for all SIX primary placements.   ;)
And then I wound 28 turns, waxed and taped my first of six primary segments.  I am using 20 gauge, solid, teflon coated, silver plated wire for the primaries.  Winding is from left to right, CCW.
I hope to do one a night, over the course of the next five nights.
Cheers,
Bruce
eldarion
Coil is looking excellent, Bruce!
Are you going to precisely space the primary windings like you did to the secondary?  (Not sure if that's really neccessary, just thought I'd ask.)
Attached is a (blurry, sorry!) screenshot of the current controller, displaying fake data of course. ;)  As you can see, I am planning to make the controller able to handle two cores at once for increased power output...I still have a lot of work to go...
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bob Boyce
Quote from: btentzer on September 23, 2007, 01:17:47 AM
Hello All,
Cheers,
Bruce
Tried posting this last night but my browser kept crashing when I loaded pages here...
Bruce, hard to tell here on this small laptop screen, but that sure looks CW to me. It looks like the camera is closest to the finish end of the winding, and the winding at that end is exiting at the top, When I tried clicking on the image to save so I could open it in a program and blow it up, the image would not download. So I can't be sure. Remember, the way to determine direction of wind is by looking at it from the point of view of CCW wave fronts passing through the centerline of the coil from start to end. The windings should be corkscrewing CCW as you are passing through that coil from start to finish.
Bob
