Tesla + Meyer + water
Started by Lightwave, May 30, 2005, 03:53:29 PM
mikestocks2006
Quote from: tao on June 01, 2006, 05:56:31 PM
Exactly mike,
That would easily show the system working. Cell->Gas Generator->Cell. LOOPED.
Just like JL Naudin did with his bingo fuel, expect the bingo fuel process ATE all the carbon ;). http://jlnlabs.imars.com/bingofuel/html/bfr5hpgen.htm
Anyway, Meyer was using the alternator to run his cell demos because that was exactly how his system would look in a car, with its electrical system.
aha!! there it is. Ok, is the power supply that feeds the cell, hooked up to the Honda generator? It's not clear from the pics. If it is, then that's the answer period. Do they have any power output tests done on the generator? Idling at no load, may not be enough, as the cell seems to draw considerble power, from reading the description it's pulling about 30V x 81 Amps
mikestocks2006
Quote from: tao on June 01, 2006, 08:58:19 PM
The power supply first feeds the cell but then the cell power comes right from the generator. You can see this in the video when they switch power sources, after the generator is running.
Only problem with the BingoFuel is that it consumes carbon for its reactions to take place and that is why the generator stops in the video. If you ran a car on the stuff, you would be running your car on water and carbon rods, lol. ;)
In that video from the site/page above,
I see they turn on the power supply before they start the engine. Which is ok because they need to get the cell and gas generation going before they pullstart the engine.
But after that the pesron who turned the power supply on, moves away and I don't see a switch to get a feed back from the engine. Are there any other videos that show the feedback of power from the engine/generator back to the power supply that feeds the cell?
Fully agree on the supply of carbon rods, depending on how fast they are used up it may not be practical. :)
However; it sure demonstrates the proccess.
Ros-Co.
mikestocks2006  I NEVER measure more than few kiloohm resistance.  It is impossible to keep very clean the water, and ay waste dramatically increases ionic conductivity.   But Meyer said, it works with normal tap water and saltwater.
Or the resonance maybe changes the conductivity of the cell?  I don't know.
There is a video on NORMAL electrolisis, 12V 10A with normal tap water, and 1,5mm gap.  few ohms..
http://www.hvlabs.hu/zpe/horvath/MVI_3287.AVI
I have an idea for bingofuel.  using carbon rods to generate gas is difficult, and not efficient.   A fine dust of carbon "emulsion"  on the water should be used.  And some arcing under the water  needed.  Maybe it generates more gas, and you don t need carbon rods, only some piece of carbon.  I think its less difficult to drive a car.
mikestocks2006
Quote from: Ros-Co. on June 02, 2006, 03:01:25 AM
Yes it may very well be the impurities, that bring the resistance measurements lower. Agree on the higher frequencies and possibly the mentioned in some sources "cascade effect" would effect the resistivity.
Thanks for the numbers and the video ref. Nice work! Did you ever try distilled and/or de-ionized water?
Ros-Co.
Hi!
Thanx.  :)
In the video there was tap water.  With distilled water it doesn'n work.  I use clear distilled water (not deionised) from Chemist's.  But any waste on electrodes, easily pollute the water.
Ros-Co.
