Molina Martinez patent
Started by hartiberlin, August 12, 2007, 11:08:53 AM
hartiberlin
Hi All,
I created this board and topic to discuss the
Alberto Molina-Martinez patent and his unit.
He wants to join this forum and we give him a new home over here.
Regards, Stefan.
brnbrade
Hi
Welcome Alberto Molina-Martinez.
regards
Alberto Molina M.
Hello Stefan,
Thank you for the invitation to the forum. Also to B. Tentzer and brnbrade.
I have seen some comments about my prior patent on the ?Continuous Electrical Generator? of year 2000. I want to say publicly that despite all my efforts of many years and hundreds of tests, probably thousands, it never performed as an over-unity device. At some point it seemed to be far over the unity, probably 14 to 16 times the power it was consuming, but it proved to be only apparent power, not real power.
I could run motors, turn on light bulbs, etc, as I say in that patent, but it only happened because it was actually behaving as an electromagnetically rotational transformer, but not a generator.
I knew early in work that there was something missing for this machine to work properly, and I spent many years on its search. Over-unity devices must have an identifiable source of energy, and this device was lacking one.
For some reason I have not trusted permanent magnets as a source of energy. I believe that it is possible to build over-unity devices with them, probably there are many out there already, but their efficiency will hardly be big enough to be used as a source of energy to redeem the world.
By 2004, while searching for a possible solution, I found my self immersed into the concept of antimatter. It was after all the most powerful source of energy known to humanity. But, could it be harnessed in a safe and economic way to be used as energy source? The answer you still find everywhere in the internet, laboratories, universities, research centers, is NO.
I?m not the kind of guy that takes a NO for an answer, for what I decided to go deep into the theme. Among all types of collisions of particles tested in physics research laboratories, I found that the collision of photons yield the most energy of all. According to CERN, the European Organization for Nuclear Research, a collision of 2 photons can produce 183 to 209 Giga-electron-volts, far over the energy produced by the collision of any other particles or antiparticles.
The collisions of photons generate quarks and antiquarks, which in turn convert into beams of particles and antiparticles, releasing a formidable amount of energy.
The Antimatter Electrical Generator.
The deeper I went into particle physics, the more certain I was that the collision of photons was the answer I had been looking for so long. It was a source of energy in itself; the difficulty was how to harness it in a practical way.
Photons have the peculiarity that they do not collide spontaneously. You have to concentrate and direct them to force a collision, and either then, only a few of them would collide. So, the challenge was to increase their concentration to the maximum extent possible and some how make them collide.
My first design was to confront two powerful laser beams at the center of a collecting chamber. I had even written a patent for this design, when the idea came that I could use a single laser chamber if I didn?t allow photons to escape.
The result was the Self-Reflective Chamber or Photonic Reactor that I describe in my new patent, the ?Antimatter Electrical Generator?. See the complete patent in: http://www.givetheplanetachance.com/
Summary of the Patent
?The invention refers to a system for the practical and inexpensive procurement of huge amounts of energy derived from the principles of matter-antimatter generation and annihilation.
The foundation of the system is a specially designed Self-Reflective Chamber or Photonic Reactor, which will generate photons within a totally confined space at a continuous and increasing rate, not allowing said photons to escape the chamber.
Photons will travel in all directions at the speed of light, just to be reflected back by the chamber walls.
Hundreds of trillions of photons traveling at the speed of light will be crossing paths with other photons in a high and continuously increasing density, until they will start colliding with other photons, at a rising rate. The photon density will continue to increase until the number of collisions enters in equilibrium with the production of new photons.
Each of those collisions will produce jets of subatomic particles and antiparticles, which, this time, will pass across the walls of the Self-Reflective Chamber creating a continuous flow of particles and antiparticles toward the exterior of said Self-Reflecting Chamber or Photonic Reactor.
Those charged particles and antiparticles will cross through the atoms at rest of specialized Collecting Chambers generating ion-pairs dissociations; this is electrons and positrons (the antielectrons).
Myriads of electrically charged particles and antiparticles passing simultaneously across the masses of the Collecting Chambers, creating ion-pairs dissociations, will generate, under the proper circumstances, what is known as avalanche multiplication.
The avalanches of electrons and positrons are then separated by the action of powerful Electromagnetic Rotational Fields, generating a very high electrical potential or Voltage across the terminals of the Collecting Chambers. The Power generated can be then utilized directly as electricity.
A second embodiment will, instead, separate the jets of particles and antiparticles by charge without any interference with matter by the use of powerful Monopolar Electromagnetic Rotational Fields. Particles and antiparticles thus created and separated can be used directly as propellant fuel for spacecraft or high trust combustion engines. Antimatter Fuel can then be produced in the site, on demand, in practically any amount.
In essence, the Antimatter Electrical Generator converts almost ordinary matter into pure energy.?
This technology has the potential to turn into an inexhaustible and inexpensive source of energy, bringing unimaginable prosperity to whole mankind.
My purpose in participating in this forum is to spread the understanding of these ideas, in the hope of finding receptivity for their development.
My best wishes to everyone,
wile_coyote7
Soooo....I'm guessing that this is NOT something we can raid a Radio Shack and build in our garage this weekend?
Sounds cool though...Kinda Star Trek-ish.
?When the power of love overcomes the love of power, the world will know peace.?
Jimi Hendrix
