Magnet Shielding.
Started by ooandioo, June 02, 2005, 06:50:51 PM
Greg
I see you need more. Make two pieces of shield that come together in the middle of the magnetic field like a titer toter on either side of the center magnetic so when one  side is closed the other side is open. on the way in the shield is attracted to the further from the center magnetic it slams shut and attracts the center magnetic at the other end the center magnetic is closest the two sides of the shield start to open the magnetic field is N-N or S-S pushing like mad the shield can't wait to get out of the way.
Light
"This is how i observed the effect, if someone else has different experiences please speak".
- Unbelievable. Guys, you ever held a magnets in hands? Of course not, but in this case you don't have to. What you have to - to think a little bit. As soon as your "shield"(!??) will be moved from this position, dipoles in it will be reoriented and this "shield" becomes a magnet, attracting to these magnets. And to move it out you need to spend some energy. As it is drawn, yes, the "shield" will be neutral, but there is no any use of it standing...You can not cheat the magnetic field. What you can - to operate it.
Greg
The shield moves out of the way when it is neutral No force the two magnetic fields are interacting with each other. look at it again light. As it is being drawn out the other side is being drawn in. If you can't visualize it build it.
