Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
ashtweth_nihilisti
Hi all, okay sorry try this, ill ask my source for you about the figures  ;D
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
RunningBare
Ah, my bad, I should have said "television crt line output transformer" to be more accurate.
Quote from: TheNOP on September 17, 2007, 09:00:45 PM
@ RunningBare
For me, "line output transformer"could mean, a conventional step up transformer, or a flyback transformer.
Sorry if i make a mistake here.
Blame it on the language barrier.  :D
BTW
If you try the sublimation of water way, i suggest that you reduce the size of your electrodes and use smaller quantity of water at a time.
At too high voltage, in Mayer's setup, the voltage will only arc from a specific point between two electrodes and will not build much differencial charges on the tubes.
tao
Quote from: RunningBare on September 17, 2007, 06:46:28 PM
The output from a modern line output transformer is DC due to the fact it has a built in diode/capacitor voltage multiplier.
Quote from: TheNOP on September 17, 2007, 06:18:41 PM
was it DC ?
if not, the plates were constantly changing polarity and  only shaking the molecules
the task is not "breaking the dielectric barrier of water".
it is to apply a force to dissociate its molecules.
imo. at 10KV the distance between plates would need to be revised.
about the schematic, i suggest to replace the lamp by a battery.  ;)
DC isn't what we want to use, we only want to use IMPULSES.
Ponder this profound example:
If you take a 1:1 transformer and put a 12V battery on the primary side of the transformer, and on the secondary side you place a bridge rectifier and a capacitor.
Now, on the primary side in series with the 12V battery and the primary of the transformer you place a simple switching device like a transistor or FETs.
Now, the start conditions are as such: The battery is at 12V, and the capacitor on the secondary is at 12V...
Having 12V on both sides of a transformer means no current flow, so if you were to apply a simple square wave to the primary of the transformer using the 12V from the battery, there is NO current flow in the secondary because the capacitor on the secondary is at 12V, UNTIL that magnetic field that was built up in the transformer collapses...
Now you have a VOLTAGE pulse (pure EMF) of anywhere from 50V-1000V, and since the primary is now an OPEN circuit, this voltage pulse moves onto the secondary, but now, since the voltage is greater than 12V, this voltage DOES ADD to what is stored in the capacitor. Capacitors are the best conversion devices for these TYPES of pure EMF pulses...
That is just one example...
So, we aren't using DC, that is Direct CURRENT, we are using improvised PULSED DC, such that we all but eliminate ALL CURRENT FLOW...
So, you CAN apply 10KV+ to stainless steel plates that are in water, and the distance wouldn't have to be revised, because we aren't ADDING electrons to the plates, only this VOLTAGE FIELD...
This is what Bedini calls his 'radiant energy'........
TheNOP
ashtweth_nihilisti
Guys, i just got given this idea for h20 loads on your WFC.
Ash, i have been research looking for the easiest and simplest and yet most efficient way to demonstrate h2 production doing work.
The way I see it, the practical solution will be to get a Sterling motor and use a flame from the gas production. Trouble is the costs for these motors and I am having trouble finding one that is not a toy but can do a reasonable amount of work.
http://www.stirlingengine.com/ecommerce/product.tcl?product_id=29
This one unfortunately is electronically heated but if we can find something like this where a direct flame can be used it would be ideal.
