Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
saintpoida
hey i tried the inductors with just a small one tube setup i made from spare tubes (not conditioned)
and with the inductors in i get pretty good production at 1amp, if i take em out
i think i get around same production but the ammeter tries to go past 5 amps
so is that sort of working or are the inductors just affecting the ammeters reading so
i am still putting in 5+ amps?
if i wire an ammeter in series directly before input will i be able to check how much its drawing
from the battery???
saintpoida
also what voltage are people getting across there output terminals?
dutchy1966
Quote from: saintpoida on October 05, 2007, 07:49:09 PM
from the battery???
Hi,
Well I must say that doesn't surprise me at all. That is exactly what the inductors are for....restricting the current. Ideally you would have NO current through the cell. In practise we won't be able to do it but it is what we are aiming for. Current through the cell is just waste energy. I know you can send amps through the cell and get HHO but that is something completely different. I's called brute force electrolysis and we are NOT trying to do that.
We want to use the VOLTAGE to do the work. Therefor the voltage across the cell should as high as possible (which can be spikes up to 20KVolts! ) and the current should be restricted as much as possible at the same time.
Yes you can use an ammeter, but i would put in in the 12v power lead. Use an anlog meter as digital ones are no good for measuring pulsing current.....  My controller has a built in analog 5A ampmeter.
Robert
atlantex
Hi all,
here a new video of me single cell after 2,5 weeks of conditioning, after 3 hours of running, the water changed the color a little bit, no brown scum is produced, and the current didn't raised.
http://www.youtube.com/watch?v=jmSz3ZORt78
it's pretty quietly, so turn your speakers on.
next step would be to build a multicell, and than mounting the whole thing to a car in connection with an EFI lambda controller.
My goal is a fuel saving rate of 20%, than create detailed instructions or may be a kit and everyone can use this technology, that would be great...
Could someone please give some information about the prices for the tubes?
best regards
atlantex
