Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
gyulasun
Hello Igor,
Very good you have returned to this topic and continue testing the RPMM.  Did you use a force meter or you used your fingers to sense the forces?  Of course the latter method is also good... ;)
Hopefully you can rebuild the base from a more robust material and continue testing.
Thanks,
Gyula
wizkycho
Quote from: gyulasun on January 20, 2009, 10:28:02 AM
Hello Igor,
Thanks,
Gyula
First sensing with fingers, as I said there is much friction since lower (input energy) rotator doesn't have any distance at one side from ring magnet (it is strongly attracted to it and bending shaft screws to plastic) If I try to lift it it flips strongly to other side. But to my opinion forces are distinct enough to feel the difference.
...but good question (opinion is not measurement)...I'm in search for two some adequate nonmagnetic springs. The spring attached to lower (input) rotator should strech less than upper
(output) rotator (streching at 180deg from one another) and this can be sensed right now.
btw.
Current cost arround 250 Euros
This setup is not intended to be new source of energy but Eyeopener, Awakening tool, Inspierer...Firestarter.
When this mechanical problems are solved there is need for additional parts (coil, Cond , transistor) to make it self runner.
Wiz
wizkycho
Hi all !
does anyone has any suggestios 'bout using this ring magnet for Homopolar generator ?
Wiz
sushimoto
hi you.
thanks for sharing all this, but why are you asking about homopolar generators,
instead of focussing on your original idea?
Are you in doubt about it? Did i miss something?
You have started this thread 4 years ago and some people
are trying to follow and helping your concept.
.... I really dont want to offend you, but after four years you did
not get something better that a bending peace of wood on a "wobbling" axis?
Right here, at this community, you will find help on the mechanical side.
It took me two hours of lifetime to follow this thread,
so please excuse if my reply sounds a bit rough. I'm engaged,enraged.whatever.
keep on track, make it spin ;D
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
wizkycho
Quote from: sushimoto on January 20, 2009, 03:51:42 PM
hi you.
I'm having fun in building and thinking 'bout this things, and when it's not fun anymore (when someone like You bumps in), I give a little (or more) further effort and then I stop and do somethng else (in this field). This is in fact the way of life I want and why I'm on this - to stop being anyones slave, for reason I don't agree with, not even Yours.
You think 4 years is long ... what are you doing here ? In 2 millions of years of evolution of mankind man has to do work for energy (now more then ever), never was free - so I have all the time in the world, even I don't succeed.
Yes You are engaged,enraged...so why don't You make it spin right now and right away.
You are only excused to "waste" some more time and money then two hours (on whatever topic You wish).
I'm not jumping from setup to setup leaving and discrediting possible principle of work,
unless I make setup exactly as I wanted it to be and it doesn't work
(even then I might be wrong so nothing I make goes to junk - One can not force the right idea to bump right in when You want it in a split second).
I'm making several setups (dif. principle of work) in paralel - same reason waiting for the idea. In process I allso have to make tools.
Seems like You haven't ever even tried to make any of setups...try it...you'll come up to many problems (you tought are already solved by this civilization)...good luck.
This setup pushed me to buy this ring magnet, while building it I relized that I have magnet (somewhat easily dissmounted) that might fit to homopolar gen. or SEG type...
There are no fully credible and replicapable,verifiable Homopolar generator replications not recently. Principle of Work is on the other hand very exact and can be used as Free Energy generator not toy.
You say I don't deliver ... tell me one thing in this world that does - so how can I do much better.
This is why we are here to make something we can relay on.
Wiz
