Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
wizkycho
Quote from: m668004 on June 05, 2005, 06:25:02 PM
@Light
QuoteIn God's sake, Wizk, WHY the rotor's magnet will follow the "screen"? System is closed, they (rotor and screen) just attract each other and all system will stop.
The rotor magnets will follow the shielding because the shielding moves. Don't forget: that's not a selfrunner. It needs a permanent energy input. You have to rotate the shielding permanently. And then the rotormagnets MUST follow because the place behind the shielding is the only place with little or no repelling forces.
M.
BRAVOOOOOOOOO !
Even if there is Output Rotor attract Input Rotor (very thick shield,poorly constructed) sittuation is this
I will INPUT Output rotor - input rotor (shield) attraction energy =Eattraction
but I'll get for free Repel energy between outer ring magnet and output rotor =Erepel
therefore on input rotor = Eattraction
on output rotor I'll get = Eattraction + Erepulsion and we are still very much over 100%this is really the worst case scenario.
Thx
wizkycho
Quote from: m668004 on June 05, 2005, 06:35:29 PM
@wizkycho
Quotethe magnetic field is strongest in CENTER
I'm not sure about this. Look at the picture. Both the flux density and the density of the fieldlines are greater on the outer edges of the magnet.
M.
@wizkycho
M.
It wasn't shown in video but washer (you can see) wan't stay in center when applyed horizontally, but stands perfectly
still in center when placed 90deg.
allso You can notice that half of washer (when bounced) stick to magnet the other half stays in air.
SO FOR THIS BEHAVIOUR OF FERROMAGNETIC MATERIAL IS RESPONSIBLE DENSITY OF THE FLUX DIRECTLY CONNECTED TO IT'S SATTURATION CAPABILITYES.
Light
"that's not a selfrunner. It needs a permanent energy"
- No use to discuss it then. I thought it's OU site...
wizkycho
Quote from: Light on June 05, 2005, 06:56:10 PM
It gives much much more energy OUT than the INPUT is. It is up to You will You close the loop and make it to work in
OU mode, just for You.
pinobot
Light, the concept that one idea leads to another completely eludes you doesn't it?
To boldly stay home.
