Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
wizkycho
Quote from: m668004 on June 06, 2005, 06:11:46 PM
@wizkycho and all
To allow an easy to build device I changed the design a little bit. Please look at the picture. Only 3 magnets would be needed. 1 ringmagnet as stator and 2 diskmagnets as output-rotor. The picture is only a scheme. In my opinion this design would work too if the working principle is valid. What do you think?
M.
May I, with Your permission put this lower complexity type on my site ? I'll make an animation.
wizkycho
I allready have 20 pieces of very strong NdFeB round magnets for Outputrotor
dimensions are? 20mm diameter 1cm thick properly polarized.
BTW: this one works on repel. can we think of attractional analogy of this device - and prolong working period from
500 years to more than 1000 years and desolve any susspicion that may apply to repel action of original device ?
this just for some brain storming.
ooandioo
I also have strong NdFeB round magnets (N42), and I'm going to get some Ironplates.
I order my magnets at www.supermagnete.de, they are also offering comm. specification ordering and I will ask for a ring magnet size 100mm x 20mm x 10mm.
If the idea is working, we will have a prototype soon...
Tell about your experiences while building.
m668004
@wizkycho
QuoteMay I, with Your permission put this lower complexity type on my site ?
Of course. No problem.
M.
wizkycho
Quote from: ooandioo on June 07, 2005, 05:42:22 AM
i advise You to reconsider using bigger diameter of ring. Between to sides (180deg) of this ring 100mm is only 60mm 6cm. And if magnets are NdFeB and strong Ring puts repel force ONITSELF and discharges (not quickly? but still does).
Rotor magnets will allso repel each other at that distance (very noticeably), which is going to weaken ther action.
Many other unexpected things (more likely unuseable) can arrive from this i think underdimensioned ring
if using 200mm diameter the space between to sides is 16cm and at that distance you can not or unnoticeably see
(feel) repel between two magnets NdFeB (N42).
100mm would be cheaper BUT BETTER RETHINK IT
