Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
wizkycho
Quote from: ooandioo on June 20, 2005, 06:37:05 AM
Hi guys.
Any news from you. wizkycho, did you get your magnets?
greetings, Andi.
      I had a meeting with a person nicknamed Shad and he showed me a material wich has very good shielding properties.
It doesn't interract with magnet (no attraction,nor repulsion) but when between two very strong NdFeB magnets acts like it "consumes" field and two magnets can be brought much much closer. 5 cm distance without material to feel repulsion and 1cm with material inbetween magnets to feel repulsion. At first he claimed that he gathered this material from beech using magnet and that this material is black sand (volcanic origin).
     After a while he tells that this is common ferrite material used for radio receiving oscilating circuit, but he conditioned it (he of course will never tell how).btw material is 5mm thick with diameter 3.5cm.
      This is I suppose process he used: he took ferrite material from some kind of electronic aparatus (radio receiver)and used hammer and smashed this ferrite (it is very brittle) till he got sandlike form. Then he mixed this sandliked ferrite
with acrylic glue (super glue) and put this mix into round shaped (5mm deep) form made from paper (there are residues of paper on his sample I sow).
      The conditioning has been probably made with alternating current (common 50hz but through trafo 50W/6V~) through coil he wounded parallel to diameter. this way he got little hallbachs that acrillyc fixed to be permanent paths for outside field.
       Why he did not revieled this process completely ? He invested a lots of money in some patents (neutrino diffuzor allso called fuel cracker (allso cracks water with this)) so the only way (he sees) is to meet some rich industrial who will
buy off this patents from him in order to get out of money debth.
       If You meet this guy tell him that most likely he and his patents and methods will be forgotten and lost
through time (rich industrials have doesns of such patents and they only searching the right time to sell it but under some different "name and usage and characteristics" in order to keep unquestionable control and earn more of Our money(sweat ... even blood) so they can feel as kings amongst the beggars(what a perversion!!!!)).
Igor Knitel
ooandioo
This is amazing and would be a great advantage to our work. Your system would be guaranteed to operate with such a material.
We will need to get such a material immediately...
-- Andi
hartiberlin
Quote from: wizkycho on June 21, 2005, 04:30:50 AM
I had a meeting with a person nicknamed Shad and he showed me a material wich has very good shielding properties.......
Igor Knitel
Hi Igor,
did you visit Shad in Zagreb at his home ?
Did he show you also his gocart ?
Does it already run powered only on his neurtrino egg diffusor and
water ?
Is SHAD still believing the tales of the rich invenstors buying his inventions ?
If he would have gone public domain years ago with his Neutrino egg,
then he would be already famous by now and would make
much more money already now....
Regards, Stefan.
wizkycho
Quote from: hartiberlin on June 25, 2005, 08:40:53 AM
Igor Knitel
Hi Igor,
water ?
Regards, Stefan.
Igor Knitel
Hi Igor,
water ?
Regards, Stefan.
Yes it works and we are driving it across our countrys new A1 autobahn ! Yappiiiiiii 380 Km up und down with no stopping for fuel.
hartiberlin
@wizkycho
Can you please post a few pics of the gocart ?
Or just tell SHAD to post some reports about it.
How much water did it need for the 380 km ?
Thanks.
Regards. Stefan.
