ZeroFossilFuel is the man!
Started by RunningBare, September 02, 2007, 09:05:57 AM
eandatoo
Hey, Zero
Can you use the electrolyzer cell to run a vehicle on 100% HHO? Is there a special configuration needed to enable this? It would be great to totaly eliminate the need for fossil fuels.
readyakira
Quote from: mrgalleria on December 10, 2007, 10:00:28 PM
Aloha,
Some people use a little windshield washer pump after the cell to maintain vacuum.
I prefer running without the bubbler, and have done so without problem. Using barbed fittings without clamps at some points is good insurance in the unlikely event of an explosion. Be sure, as you should know, to retard your timing as needed.
I am pretty sure it is advance the timing, as timing is already retarded to start the slow combustion just before TDC.  If you ran regular petrol at TDC alot of the power would be lost due to the fact the piston is on the down stroke when the expansion begins.  Thus you advance the timing because HHO should make the mixture burn faster and more complete.  The bubbler can have a second added advantage by introducing a water vapor to the mix, thus slowing the combustion down and reducing the need for as much timing advancement.  I was thinking of actually using an airstone in the bottom of the bubbler to add more vapor to the gas mix, and maybe be able to eliminate the need for timing advancement.  Of course the major reason for me trying this is because I am using a OBDII truck for my experiments, and adjusting timings and fuel is more then just turning the distributor.
mrgalleria
Aloha,
Actually to retard the timing means that it will fire later, to advance the timing means that it will fire sooner. Your own argument states that you want it to fire later, not sooner.
The bubbler will not add more vapor, it will remove most off the heavy vapor coming from the WFC. Use a bubbler, it is important. I use the airstone- aquarium bubbler.
nul-points
hey Zero, LTNS
looks like we've both had some interesting developments since we last emailed
did you get anywhere with that PMM?
regards
sandy
Doc Ringwood's Free Energy site:
  http://ringcomps.co.uk/doc
Mark69
@ZFF and IH
Is this the same cell that produces the parahydrogen from you other post (highvoltage HHO by Ironhead"???
Mark
