Linnard?s patent is out ! Splitting H2O just with a catalysator !
Started by hartiberlin, June 06, 2005, 09:23:32 AM
Kator01
Please rember that you do not consume up the water reservoire at all because when you burn H2 you give H2O back to nature.
I put this writing of Bruce only because it may be an interesting way : Because you only add water and keep the tank
closed only using H2, the radionuclei remain in the tank and do not escape.
I do not prefer this methode either- I agree.
Kator01
Paul-R
Quote from: kenbo0422 on July 12, 2005, 02:03:52 PM
I would imagine that producing colloidal aluminum and lead would be the same process as producing colloidal silver for health reasons.? 30v DC and two very pure silver bars or coins and let the electrolysis erode the metal into a container of water.
Aluminium and lead are nasty elements healthwise. In colloidal form, possibly more so. Alzheimers etc. The Land of Rubber Gloves beckons !
WolfRAM
The principle behind a catalyst is that it just allow the reaction to occur without
being used, if it's consumed in the reaction well it therefore becomes the fuel,
so much for catalytic reaction... it's mearly a chemical reaction that burns-up the
catalyst to produce hydrogen gaz by leaving the mixture little bit more neutral...
I just studied chemistry at University but who knows!!!
hartiberlin
Hi Linnard,
I did today try your experiment #6 from your patent,
where you stated , that one can use 20 mL of Iron-3-Chlorid ( FeCl3)
and 10 mL of colloidal Magnesium and
20 mL of colloidal lead and mix this together.
But when I did this, there is no hydrogen or oxyhydrogen
generated.
It is just a light brown colored watermix...
I got the Iron-3-Chlorid ( FeCl3) from an electronics shop,
where they normally sell it for aetching circuit boards.
There are small ball sized green pellets about 1/4 inch in diameter
and the bottle in which it came said it contains
60 % FeCl3.
Hmm, how strong must the solution be ?
Maybe it contains still too much other stuff, that is not good for your reaction process ?
I also had only AZ61 magnesium alloy rods, which I used for the
colloidal silver pulser device I have, which I normally use to make
colloidal silver water for myself.
Maybe the AZ61 contains too much Manganese or copper ,
so it does not work ?
ALso the lead I had was from a fisherman shop, where they sell it as the weights
for fishing line hooks...
Hmm, maybe this way also not pure lead ?
I let the colloidal process run in starting at boiling destilled water and let it
run for more than half an hour and it got around 30 Volts DC pulses all the time
from the pulser device.
So now I am asking myself, how I can still try different setups ?
I used only about 3 to 4 small FeCL3 balls in about 0.2 Liter of water, so the
solution was pretty brown, but maybe this was too low of a concentration ?
For the aetching it was said, to use 250 gramms on 1 Liter, so this is
a pretty big concentration then...
Hmm... Can you give me some hints to verify your process ?
Many thanks.
P.S: DO you have a website for your new AirGen Corp. company yet ?
Best regards, Stefan.
hartiberlin
I got this answer back from Linnard today:
Hi Stefan,
This experiment was done to prove the regeneration of metals not for bulk
hydrogen production. The metals I used to produce the colloidal solution
and the iron chloride , were pure. This is a acid reaction, and the total
solution volume was 100 ML .
Hope this helps
Linnard
PS: no website
