Overunity perpetual motion motor magnets
Started by FreeEnergy, September 07, 2007, 04:02:10 AM
Brian Leonard Marshall
Hi, I think I can. With magnets if we bring two south poles or north poles together they repel, so the enrgy required is the same as as the repulsion. What I have done is remove the repulsion as the magnets are brought together, then as they pass each other the repulsion is switched on and this is why the movement is very powerful away in the direction shown. In this case there is no energy used up bringing the magnets into the 'fire' position.
I thought of it as a stream of magnetic gauze that I could take advantage of like placing a paddel in a river. This was what I had in mind when designing the layout, to regard it not as a repulsion but a flow.  To acheive that I allow the south and north poles attract then by the trigger I invented, once the poles are aligned, the poles act as if they are like poles and repel.  The power is such that the next set is entered and they also repel the rotor and so on.  Thus far the latest unit spins up so fast I have to retract the rotor something like the Howard Johnson motor, and in this way can vary the power out put.
Hope that helps
Cheers Brian Leonard Golightly Marshall
hartiberlin
Hi Brian,
many thanks for this info.
Do you use any electronics and coils as the helpers to achive this or is this purely mechanic ?
Or do you use any iron shield plates with it that slide into position ?
hansvonlieven
G'day Brian and all,
Quote from: Brian Leonard Marshall on September 15, 2007, 12:44:14 AM
If you have pulled this one off it's THE trick of about half a millennium. It'll make Einstein and Newton and a few others look silly.
This one Ive got to see.
Hans von Lieven
Omnibus
"the trigger I invented", that's the crux of the matter. Tell us about this trigger. Everything else is beside the point.
Freezer
Well if what you say is true and you have found a way to nullify the incoming resistance, then congrats.  I've been wondering for so long how that could be achieved, but never could think of a way.  Are you gonna give away the secrets?  No problem either way, but it seems like you made something that very few could do.
