Very legit and promising desgin!
Started by skycaptain, September 07, 2007, 04:27:54 PM
Freezer
Simple Guide to Debunking:
1.  State that UFO's can't possibly exist because you haven't seen one.
2.  State that all sightings from credible witnesses are swamp gas from uranus.
3.  State that all credible military personal to speak of UFO's are lying.
4.  UFO's can't exist because travelling to other star systems is impossible with man-made technology, and no alien race could ever surpass our technology.
5.  If you work for NASA(Never A Straight Answer), state all anomolies are ice crystals.
skycaptain
Quote from: nightlife on September 27, 2007, 04:06:11 AM
As for a magnetic motor, there are several ways to build one. I was personally going to build one using electronic magnets and permanent magnets and positioning sensors, The sensors would be used like a crank shaft position sensor. It would create a pulse that would activate a electronic magnet to attract the upcoming magnet and then another pulse with the electric magnets polarity switched causing it to push the permanent magnet away.
This would allow us to use the full benefit of the permanent magnets magnetic force.
I forgot to add the fact that it would use multiple permanent magnets and electromagnets with the permanent magnets fixed to a wheel that would rotate and the electromagnets would fixed to a fixed outer perimeter that would surround the wheel.
The wheel would have a shaft through the center that would house a electric generating device on each side of it.
This could be tied into a battery setup that when fully charged to a recommended amp, it would shut down the motor and restart it when they fall under a certain amp. This would help preserve the life of the motor.
There would be other devices needed like a voltage regulator and solenoids to switch the electromagnets polarity?s.
If anyone is inerested, email me at browns49015@yahoo.com
It seems that what your describing is of the most basic electric motors...?
Did you mean electromagnets setup with permanant magnets in a parralel path setup, like joseph flynns motors, or like hildenbrand?
Is it any significantly different from them?
skycaptain
Then tell us your desgin.
But it still seems like what you have is still a basic electric motor nothing to fund, just got buy a toy car and there you go!
