DDS based function generators
Started by MeggerMan, September 08, 2007, 03:11:24 PM
MeggerMan
This topic is to cover the parts required to build a DDS function generator.
Currently I am working on an inverter board for the DDS 20 function generator to provide the -5V rail for the high speed video op amp that produces the sine wave.
This uses the +5V rail from the DDS 20 to power it and after searching for every kind of inverter and dc-dc chip I came up with the TPS6735.
Schematic
http://i100.photobucket.com/albums/m25/kingrs/inverter_schematic_v1-0.jpg
Board
http://i100.photobucket.com/albums/m25/kingrs/inverter_layoutv1-0.jpg
Blanks
http://i100.photobucket.com/albums/m25/kingrs/inverter_pcb_blank_v1.jpg
Built
http://i100.photobucket.com/albums/m25/kingrs/inverter_built_v1.jpg
The output voltage is -4.946 volts at 60mA load with about 10mV of ripple although the scope shows about 18mV of noise anyway so its hard to tell what the real ripple is.
The power required by the op amp is about 25mA.
After struggling with removing the existing components I have decided to re-think the layout and drop the PCB directly onto the main PCB and make use of the existing components. The only component I am not sure about is the 7905 voltage reg. and the question is will the regulator cause a drain on the system in passive mode - if so I will need to cut the track.
Rob
MeggerMan
DDS 20 with ali case and collet type knobs (medium on the rotary encoder and small on the sine wave amplitude)
http://i100.photobucket.com/albums/m25/kingrs/DDS20_case_knobs_medium_small.jpg
knobs medium and medium
http://i100.photobucket.com/albums/m25/kingrs/DDS20_case_knobs_medium_medium.jpg
knobs large and medium
http://i100.photobucket.com/albums/m25/kingrs/DDS20_case_knobs_large_medium.jpg
Delay line compared with the AD9959
http://i100.photobucket.com/albums/m25/kingrs/DS1023-100_AD9959.jpg
top view under scope
http://i100.photobucket.com/albums/m25/kingrs/AD9959vSOIC_top.jpg
DS1023-100+ and AD9959
http://i100.photobucket.com/albums/m25/kingrs/AD9959vSOIC.jpg
DIL 8 showing just the narrow tips and AD9959, side view of the AD9959 appears to show the leads as quite wide where the underside view shows a much narrower pad.
http://i100.photobucket.com/albums/m25/kingrs/AD9959vDIL8.jpg
Rob
MarkSnoswell
Very nice Rob -- looks like you are well set up there.
9959 -- Wow -- tiny!
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
MeggerMan
I now have the samples for the PIC16F887 microcontroller. 1 x 40Pin DIP and 3 x 44 pin TQFP (thin square flat package).
I have tested the 40 pin DIP in a breadboard and can confirm that using it with the Pickit 2 flash programmer, I am able to do in circuit debugging in assembler.
Next step is to get the code I found that uses the 16F628 and AD9833 to compile in MPASM IDE and convert to run on the 16F887 and use the AD9959:
Description as follows:
Quote;*************************************************************************
; DDS_F_Gen.asm
; Processor: PIC 16F628 Clocked at : 25MHz (EXT Osc) DDS CLOCK
; (Re)Coded: 26/03/05 Author :MRB
; Revision tracking: Ver. 1.01 :(1st issue, 1 changes/fixes)
; FUNCTIONAL OVERVIEW
; A DIRECT DIGITAL SYNTHESIS SINE/TRIANGLE/SQUARE FUNCTION GENERATOR
; 0.0Hz TO 10MHz TO 0.1Hz RESOLUTION
; 0.0 TO 10.0 Vpp OUTPUT RANGE TO 0.1V RESOLUTION
; PUSH BUTTON CONTROL, WITH 2 X 16 LCD
; THE WAVEFORM IS SYNTHESISED USING AN ANALOG DEVICES AD9833 SPI DDS IC
; THE OUTPUT LEVEL IS CONTROLLED BY AN DS1267 SPI E-POT
; Port A I/O allocation
; PIN DIR USE
; RA0 O/P DDS FUNCTION GENERATOR IC SPI BUS FSYNC (PULLED UP)
; RA1 O/P ELECTRONIC POTENTIOMETER IC SPI BUS FSYNC (PULLED DOWN)
; RA2 O/P LCD R/S
; RA3 O/P LCD EN*
; RA4 I/P NOT USED
; Port B I/O allocation
; PIN DIR USE
; RB0 O/P LCD D4 / ALSO SPI BUS CLOCK
; RB1 O/P LCD D5 / ALSO SPI BUS DATA
; RB2 O/P LCD D6
; RB3 O/P LCD D7
; RB4 I/P SWITCH 1,UP (ACTIVE LOW,PULLED UP)
; RB5 I/P SWITCH 2,DOWN (ACTIVE LOW,PULLED UP)
; RB6 I/P SWITCH 3,LEFT (ACTIVE LOW,PULLED UP)
; RB7 I/P SWITCH 4,RIGHT (ACTIVE LOW,PULLED UP)
