Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
guruji
Quote from: dasimpson on November 11, 2010, 08:38:13 AM
what do you mean br ac side they is no ac side the power is from a battery
the set up went + of battery to read switch then to coil from coil to battery -
Hi Dasimpson yes it's from the battery but when the coil is pulsed it have BEMF as AC so put four diodes 1n4001 facing one direction (Bridge Rectifier)
then between them one put the reed switch. One side coming from battery and the other from coil. You can fill a capacitor on the DC side.
dasimpson
so what you mean is wire as nomal but take a connections of ethier side of the reed switch run thru a bridge rectifre to a cap.
lol allready ahead of you there did clench some of the spark but the rf interference was to much.
i was going to say the bemf is pulsed dc but then i relised that the pulse going to the coil would be going the opersit direction so efectivly makeing this ac.
i was also hopeing to run some leds of the cap but when i tried it the motor boged down.
my idea this time is using bedini style circuit an using the hdd motor as the rotor.
i am going to take the old connections run as 3 phase star configuration and see what power i get from that
colzilla
Found this tread really helpful, thanks too u all!
Ive not got much helpful info too post just a couple of questions if someone
Will help me out?
1. If I was to use a latched hall switch (pulses on both poles) then would
I need to have a transistor for each hall output?
Im a noob so trying too fully understand before I frazzel parts.
Been reading that site totally amped someone posted link back somewhere near page eight, I think?
Brilliant for people like me.
I get whats going on with this dynamic system.
I know how to make a cicuit for a unipolar hall with three legs, ive only got four legged, thus my question would I needto eessentially double up the circuit?
Hope that makes sense...
2. Could I put a non polarized capacitor in place off say the bemf capturing off of emitter and v++?? Just wondering if that would act as a sort of pump timed by when its full and shorts? Giving the rotor like a current boost??
Cheers
Col
