How much weight is needed to create a certain amount of power?
Started by nirvana, September 20, 2007, 09:46:49 PM
mapsrg
Using many smaller weights on a larger wheel would be advisable....see imbalance wheel in "half baked ideas"........the illustration i posted shows 12 smaller wheel mounted weights but it can be 10 times that number.Potential Energy from a certain amount of weight in may be less due to losses so the weight figure may need to be slightly more to make these up.....
hansvonlieven
G'day all,
Is that the image you are talking about??
Hans von Lieven
mapsrg
A 25Kw unit on a 10m diameter wheel will require 510.2Kg.......plus extra weight to overcome losses.
mapsrg
mapsrg
The rpm problem........if in the calculation gravity is in metres per second then a quarter turn from the 3oclock position must take 1 second........so a full rotation will take 4 seconds??Or is it gravity will cause the weight to rotate around the wheel 9.8 metres of circumference in 1 second?................... ???
