Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
aleks
Quote from: giantkiller on April 16, 2008, 12:13:52 PMThe 2 opposing loops are really a spin accelerator with the magfields hitting each other between the loops.
What is more important is how you pulse the coils in both loops. If you are pulsing them in concord, this will work as accelerator. If pulsing them in opposite cycle directions I fail to see how they can accelerate. Spheric's variant looks working to me (with a top center coil pulsing every time a control coil is pulsed), but not an opposite cycle direction pulsing.
sparks
     I imagine the rocket engines have a little bit of plasma formation which is quite capable of disrupting the aetheric resonance with magnetic response moving perpendicular to a plasmic electrical field.  Most delaval nozzles used on rockets and turbines get their thrust from the expansion of the supersonic fluid flow through the throat of the nozzle into the exhaust chamber.  Maybe it creates SM's secret frequency of conversion sound waves in the process.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
Quote from: aleks on April 16, 2008, 12:24:07 PM
           The two opposing magnetic fields looks to me like they create energy milling fields.
Think Legacy
Spread the Love
aleks
Quote from: sparks on April 16, 2008, 12:54:58 PMThe two opposing magnetic fields looks to me like they create energy milling fields.
Yep, I agree. That's why they should actually slow-down charges inbetween them. But what do I know?
giantkiller
Quote from: aleks on April 16, 2008, 12:59:20 PM
And the funny thing is of the 4 good coils I have anybody really only needs 2 rings of 17in diam of 4 loops.
So I have simple setups to do, new additions to on going setups.
I think I mentined this before but if you pulse a ring at 5khz since the pulse is longer than the wire distance you get a DC magnetic component. 8)
I attached the 17in diam spreadsheet pic to show the freqs. With multiple turns per loop the field expands each revolution. And when the pulse ends the field returns to the wire closer each revolution. Almost sounds like a sawtooth wave. Wouldn't the magnetic field have latency as the potential subsides?
-giantkiller.
