Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
     @Alecks
    It is all a matter of symantics.  I defined the word realitivistic to give it some scale.  I believe the Universe is sung to us.  I want to try to explain the kick using terms of standardized physics.  I think it is alot easier for people to grasp ideas when they are able to visualize particles and fluids.
    The earth's dc magnetic field genertated by the spinning electron's Earth has and the resulting  magnetic isobars is easier (at least for me)  to visualize the Dynamo theory than perceiving it in terms of electromagnetic wave interaction.  Some people see the numbers-some people see the sounds-some people see the particles.  Tower of Babel comes to mind.
    Whoa Whoo Listen to the Music-  Whoa Whoo see the music sometimes. :)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
Think Legacy
Spread the Love
aleks
Quote from: sparks on April 18, 2008, 09:24:20 AMIt is all a matter of symantics.  I defined the word realitivistic to give it some scale.  I believe the Universe is sung to us.  I want to try to explain the kick using terms of standardized physics.
I do not think it is about semantics alone. Gravity being an acoustic wave of zero frequency is a physical clue: start at soundwave of high frequency, then go down to zero frequency. It is as clear as possible, you can't even perceive that in two different ways. Of course, at first you should deeply understand what soundwave is: it's not hard to do given you can create any kind of soundwaves with your body alone.
Relativistic theory does not give such clues: you will be left in vain trying to visualize anything realistic. Knowledgable people say you should not even compare its outcomes with normal 3D world reasoning. So, this theory is purely virtual.
innovation_station
in the 6 freq bucket or the "Keely Bucket" this is 1 use for it...
look at the sm 17 the balums  ;)
now steel core or iron or ferroite  absourb the flux where as plastic coper or alum repel or reflect the flux or i guess you can call it internal flux or external flux  in the sm17 i think we use creative engery from{ the inside out} oposed to destructive {from the outside in}
if a coper core  or plastic  were used we could create a magnet external rotating vortex from the center out  and the collector be set into the standing wave  or ring if you like  wich will be located outside of the balum  at a distance deturmined by the freqs also the size of the balum ring might just reflect the size of the outter collector to a ratio not so sure ......
or you could use a balum and saturate it .....  till it spews out every where  if this is the case you could use a 5 watt tube amp and a few 4 ohm coils wound on a plastic core or a ferroite balum
also i dont know about the freqs as far as i have seen you can mix any freqs and by adjusting just 1 of the freqs you can change dirriction of spinn as well as the speed of the rotation so .....
all that being said
some one must try it out
ist
sparks
   I can see inertial frames with potential energy in them relating to each other.  I don't know if this is from a misunderstanding of relativity but I was studying general relativity when it popped into my "inside eye".  I see gravity as an effect arising from the characteristics of inertial frames.  The physical Universe consisting of endless inertial frames with the potential for change or energy in these frames.  Either your view or mine shows the unification.  The frames I mention are perceived only when we take a virtual snapshot.
Think Legacy
Spread the Love
