Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
Quote from: acerzw on October 11, 2007, 12:23:14 AM
@GK
That does sound rather cool, I think you would make a cool neighbor as long as sleep and siesmic stability were not a requirement!
Since you and Ist have read/seen 'The Secret' and after the above description of your 'reality' maybe I can add some of my craziness into the mix, see:
http://www.overunity.com/index.php/topic,3454.msg53958.html#msg53958
Well, somebody had to do it! Haven't worked out how to make free Dylithium, but may have explained the source of unexpected Warp Core Failure!
Sorry no extra Dylithium here, used my last batch all up producing the above... Still the next delivery should arrive soon...
Acerzw, are we here yet  ;)
In the immortal words of Jack Canfield: 'How bad do you want it?'
Obviously there are only a few of us...
--giantkiller. Hence the name.
acerzw
@GK, quite clearly you understand.. critical mass has not yet been reached, but you have fun on your side...
oh and thanks to tao for jogging me into making the link between my hobby and OU reproducability!
Acerzw  8)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
giantkiller
We can measure the characteristics of the longitudinal electric wave with commercially available instruments and this is described in detail in appendix 1. We can summarize these findings as follows:
- The longitudinal electric wave is sinus shaped, i.e. its electric field density in the longitudinal direction is sinus shaped.
- It's a standing wave, i.e. its nodes and antinodes don't change positions.
- It's a pure electric wave and it contains only the electric field (E-component).
- The longitudinal electric wave propagates through thick metal plates (and most matter) without measurable loss. It propagates through Faraday's cage.
- The longitudinal electric wave is very sensitive to electric fields and will repel from a negative field and be attracted by a positive field.
- The wavelength is proportional to the frequency.
- The wavelength is very dependant of the matter in which it propagates, i.e. the phase velocity is very different in copper, in ground (such as rock) and in air.
- The longitudinal electric waves in the 24 hours grid are coherent. All waves have the same phase (zero or 180 degrees phase), they are standing waves of even overtones.
- The longitudinal electric waves in the 8 hours grid are coherent. All waves have the same phase (zero or 180 degrees phase), they are standing waves of even overtones. The 8 hours grid is 100 % synchronized to the 24 hours grid (based on a 24 hours period).
It's assumed that the longitudinal electric wave consists of slowly propagating electrons. It probably also consists of negative ions that are collected from the space in which it propagates.
We can summarize that heat and light represents disorder. The longitudinal electric waves are meticulously organized down to the smallest detail. It's a COHERENT SYSTEM of energy that encompasses the surface of the globe.
Because the longitudinal electric waves are coherent, they will easily create resonance. Since they have a large depth of penetration they will penetrate almost all matter and create resonance far inside that matter.
So...
Slow sine waves exhibiting standing waves made up of a harmonic component.
The big speaker test shows this. I will be reproducing this test again with the frequencies that Keely and Jaros described.
I want to watch paint peel using cold energy.
Tesla stressed sine waves for the power grid.
--giantkiller.
BEP
bolt
I like your scalar ideas GK but least not forget the transmission has been proven by bench experiments to be 1.5 times faster then the speed of light! Maybe more given the right circumstances. As bearden says its a steady state wave of extremely fast transposition. If the wave is nudged it will correct through the entire length at 1.5 times the speed of light. The channels are always there trillions of them they just need to be opened and tapped.
Boreland tech showed this too many years ago.  Likewise a scalar tx rx has been proven to be at least 300% efficient. The transfer of energy is phase locked and tunneled via a complex helix tunnel vortex. This energy is somewhat different to the earths magnet field energy and could well be Energy from the Vacuum.  Its wraps up many devices that "sort" of work like  Bedinni and Jo Newman engines etc which both said the trick is to create the potential without destroying the dipole and allow normal current to flow as in Bearden talk. One thing that is clear is not required to generate huge high voltages to make scalar waves. The trick is to keep the E and the M separated. So heavy inducatance is bad as this creates EMF so no iron cores. No big coils unless its constructed to cancel out inductance and no capacitance! Wow not much left to use LOL
BTW large voltages are NOT required its not necessary to make tesla coils there are a number of bench experiments that show it will work fine down to 2 volts. Knowing this means you should keep the experimentation power levels really low. If you carry on banging coils with 200+ volts at 2 amps then you are almost certain to be producing uncontrollable scalar waves that will probably give you a brain tumor. In my view extremely short intense pulses are not required only the right sine frequncy. Well you might say well i only see an effect with pulses and not sine. Why do you think this is? The sine has the same effect except now its on a non observable plane. Only the E field is moving. The electrons are still moving but now without squares or pulses which produce harmonics which produce side effects which CAN be measured because you just collapsed the pure state into an EM crap pile that you can see and measure!!
So when you see an observable state direct locally you no longer have a scaler wave.  This is why SM said you have to know where to find the circuit potential and its NOT with a scope or volt meter. You can only see the finished product of the scalar wave and any attempt to convert it to an observable measure state kills it. Thus you can measure and see the FINAL power output of a tpu but unlikely to see the measured effect on each coil because to do this kills it. Bedinni mentions this often that even leaving a volt meter connected to a battery severely depletes the RE and the RE can only be calculated as a battery can be charged in X hours of X capacity but you can not properly measure the power of the RE only the final effect of having a fully charged battery in front of you.
So can this all really be applied to the TPU? maybe yes. When the tpu was shorted out the spark was certainly not that of a normal supply voltage but something more like static/RF and i mean VHF RF like least 150 megs. I no it isn't but certainly looked like it so we are not dealing with a regular supply voltage.The 5k is not enough to porduce this effect either. You short out 800 volts around 1 amp with a screwdriver i tell you it doenst just fizz it goes 'king BANG!!
SM said we have to find the circuit potential so this suggest its not in the usual places its in the RE collectible places. He said the collector only consists of 3 coils of three of them with 3 controls. The severe lack of windings is not akin to a normal transformer then. Why? Because many winding create inductance and inductance kills scalar and so do caps. So the collectors may very well be open and cut to length. You put the frequencies in which you can NOT measure scaler out only the final effect. The controls are perpendicular  to the collectors because we make a E wave scaler on the control which is already a spiral tunnel vortex. The sine waves produce the pure scaler which again you can not measure until the tpu is built so testing one coil at a time will see nothing.
