Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
Quote from: sparks on May 12, 2008, 10:22:55 PM
  E=MC2  isn't bullshit and you don't need to create new physics to explain how a tpu converts mass to translatory energy.  Tesla was right about the aether but Einstein was right about the mass energy relationship.  I'll leave you alone for a while GK.  Your mind spins faster than SM's magfield ever approached.  Sorry for all the quills. ;)
@Acer
   Walter Russell Trumps both of them!
I agree with all of what is said here.
Do you find youself in the middle of what is known and what is truly there?
I walk around in a daze all day trying to get a foothold on the new steps learned. The quote at work is 'OMG he walks around spoutin' energy talk and reading Telsa patents or fun!'. Them shoes is big...
So I back track. I take 3 coils off and leave only 1 steel/copper coil on. I remove the middle iron bars and shorten the whole thing to a ring. But I leave a gap at both places where I had the bar segments.  I put an empty coil in 1 gap and put control coil in the opposite gap. I will also put control coils in both gaps.
I  am going to pulse the gaps. 8)
--giantkiller.
sparks
 Same thing here.  I just tell them it is my hobby.  5kz node to antinode propogates at the same speed as the earth is spinning at.  I think when the magfield starts spinning or oscillating at this freq you are resonating with a powerfield that overloads anything we got to handle it.  The tpu needs to be driven linearly above or below and not on any harmonic.  Just intuition here so I could be all off base.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
I put the PMH back to day 1 with 1 exception . Airgaps inside the coils where the fluz flows.. I will pulse the ranges tomorrow. Couldnt wait.
This was easy. I will pulse the air gaps tomorrow.
200ma with 200khz.
--giantkiller.
giantkiller
Well here is my realization:
Tesla, Leedskalnin, SM mentioned the use of iron.
In Leedskalnin / Emery we could see the iron.
Tesla did not show in his NT382282 transformer patent the last, outer iron winding. But the 382282 is in alot of his other patents.
If you look at all of SMs coils, if it was not pointed out specifically, the viewer wouldn't even think to realize different metals when they saw wires. I sure didn't.
I put the bailing/iron wire and Tesla's mention together. And I thought the conductor mentioned was a an electrical path not a magnetic path. Leedskalnin pointed this out.
Well that is the change point because the flux flows through space. And it can be squeezed!
As I moved the iron bar away from its magnet home there were definate increasing and decreasing vibratory amplitude changes. Standing waves? I think so and that is a good thing. Now what if I make the standing wave distance a sqeeze point? So I space the junction at the standing wave distance and then pulse the coil around that air gap.
Can you say heterodyning?
So now I have a system of test that lends itself to open configurability.
I can swap things around to suite the current testing. I will call this configuration E2lego that is E squared or EE.
Hee, hee, hee!
So the next test will be to see what pulsing the magair gap does.
I can also configure the coils up again to attain the the even bigger waves I saw on the 2nd test which was the 2 coils in series.
I will change the steel and copper connections into serial and parallel connections. Like the copper in parallel while the steel in serial. And swap that the other way also. While pulsing the magair gap.
The iron segment is not connected electrically. It looks like an open-ended single line transmission. Remember all that noise?
It like playing with a spreadsheet now.
--giantkiller. I can see this on the shelves of Toys are us by Christmas.
sparks
@loner
   SM and others have warned.  You got to drive your tpu and keep it off the resonant magfield/energy spin ban of the third rock from the sun.  Otherwise your little resonant device or time machine might just resonate you into the future.
Think Legacy
Spread the Love
