Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
olecom
http://www.scribd.com/doc/95105/The-Hendershot-Motor-Mystery
Seems like macedoniacd11 was there as well as here. If fundamental principles are same as with TPUs and Steven gave them from his POV, then close look and creativity, imagination and engineering are the way forward, just like he proposed/advised.
All current "replications" attempts and talks remind me myself in age 4-5, when i was taking replaced tubes from BW TV-set and asked mom to explain/show where all those TV people live there (content of tubes was like buildings for small humans). Some time latter i was taking apart many devices and was asking one fellow TV-master to explain what is doing this or that PCB. Naive childhood.
giantkiller
@Olecom,
The basic operations that have come to the top are multistage coupled resonant rise, rotating magfield, and the combination of both.
The end of mankind's rise using male physics is finally coming to an end. Thank God!
On another note...
It takes only 2 doses of vitamin A per year to obliterate the common parasites in an African village. This save millions of lives and each dose costs 44 cents. Cheap and do you think the goverments would jump on that? Why that would cure a potential army in the way of cheap resources like diamonds, rubies, gold, and oh yeah, oil. Things will never change unless we take up Tesla's, Schaumberger's, Leedskalnin's, Keely's cause of doing this energy gig for free!
The Kunel.pdf only has major flaws in its pictures. That's all. If you look at the Leedskalnin PMH by Emery it has fat copper and fat windings and steel keeper. I did the design that fits in the middle by using iron core wires, many paths, 22awg collecters, and 26awg controls. Kunel proposes 16awg. That's fine. He also states 12v @ 1 amp @ 50hz.
European cycles.
Kunel gives all the specs for the TPU based device. All one has to is find the driving or induction coil henries for the winding count.
My attempt was a throw together just to get some pre-effect of operation. Post-effect would come after proper tuning. But this thing is, I believe the design paper. Everything is spelled out except the coil henries. These diagrams are befuddled, I believe. Or they are dead on and some description throws it off. That could be the translation errors.
The coil drivers all come to 1 line. Shorthand. You need 2. The gaps are not measured. Play with it. The core diameters are not given. More iron gives more potential because of a higher capacity of flux. But that will change the coils.
My attempt showed very promising scope shots of 1:Resonant rise, 2:The kick. After the mechanics are achieved these 2 artifacts are the electrical start into the next step.
Deyo's 3 tier, 3 ring device plays with resonant coils. Rings 1 and 3 could squeeze ring 2 field coupled harmonically. Instead of looking at the device horizontally, like the Kunel coil, the Deyo points up with 3 concentric rings or like the SM17 which points up with 3 stacked rings and the same goes for SM's other coils.
The PMH proves you can control a magnetic field in another medium. You don't have to generate. The flux is it. It's free.
--giantkiller. 8)
olecom
Quote from: giantkiller on June 28, 2008, 10:45:34 AM
@Olecom,
European cycles.
And same sci-people say, that intelligent design is crap and evolution is not. Ha-ha-ha.
(Kunel.pdf -- i'd like to see this one. TIA for any link.)
On another note...
Nature knows how to keep balance in the wild between parasites, viruses and huge variety of higher creatures on the Earth. I'm not a racist, but face it: somebody is parasite, and corrupted govs and busies and many others just multiply them along with waste and garbage on all levels... That's why i hate to read insults towards inventors who don't disclose everything on silver plate. Not understanding their souls, yet to want understand technology isn't right methodology imho. Here must be tuning on resonance also. And maybe this is the key thing and all those dimensions, arrangements and numbers are not.
Once you feel it, you can do it. Otherwise it's a greed and waste of time.
BTW, who greedily argues about (lost) Stradivari's or Leedskalnin's accomplishmets, wisdom, craft and knowledge?
giantkiller
google:  kunel patent
http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf
Now mind you he is only diagramming the synopsis of operation. I don't see how he could use the induction windings there at 50 hz and only 1 amp.
The E2lego pmh I did had increased windings and at that level, produced the squeezing and resonant rise which I had not seen posted before. Not that I did it. Just that I increased the windings between Leedskalnin and Kundel. Also notice where the gap is in Kunel figure 2. He gives very good placement descriptions but no measurements. Same kind of illusiveness in the winding specs. But in order to claim over unity he has to mention the input and output parameters. And that applies directly to the electrical schematic which, again, in my eyes doesn't jive. This is not to say he is wrong. Things are sparse. But this a very good head start. Match the ring in figure 7 to the last scenes in the Stan Deyo video. Crop circles could'nt be any clearer. Kunel even shows the flux direction. Now use the control coils item #3 to squeeze the flux. Cannonballs.
Now lets have some real fun. The large loops in the SM17 were actually the drive lines like in the Kunel patent. Such trickery, eh? Or if they are iron wire then the control coils and magnets are in the black box. Wouldn't take much would it? SM cuts the loops at the outer most edge. Nothing is apparent, really. But the shenanagans leads us to believe that is a primary area. I don't think so.
--giantkiller.
giantkiller
Let's have a look at the GK4 again. This time it is matched against the Kunel patent figure #7, the ring. They are close in that there is flux squeezing going on. The GK4 has additional feedback forming a mobius strip. This happens at each layer and vertically when you take into account the 3 frequencies aligning and misaligning.
No magnet in place. But the iron has latency and that looks like a dc field which is the field I can squeeze.
Leedskalnin and Kunel both stated the use of a magnet gives free flow of energy trapped in the flux that is passed on to the iron loop. Rotating field.
I am sooooo glad the resistors were in the circuit!
Kunel patent page 9 states that these things can be coupled into bigger and bigger units.
--giantkiller.
