Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
singerxyz
Giantkiller,
I was telling you about one of my experiments where I used a pulse circuit through a transformer, and I said it wasn't able to do real work...
Well, now it can! I switched to electrolytic capacitors on the output and used a 555 timer/relay switch between the caps and the load to let the caps build up a charge, and I can light a flashlight bulb, or run a small electric motor for the time it takes for the caps to drain.
I can also (slowly) charge anything up to a 12V battery with it, and it seems to be a real charge. All off 3AA batteries. (They last @ 12-18 hours!)
very exciting!
NOTE: This diagram shows the old capacitor setup. I'm now using 35V 4700uF electrolytic caps
and the output is @ 70-80VDC (which is actually just ramped up  charge in the caps, but it does have amperage as evidenced by the ability to do work...)
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
innovation_station
i started to build today  but nothing like this
nice work singerxyz
ist
well i built my locked loop  electro magnet  and yes verry easy to achive this  it suports it own weight no problem i only charged with low current and it works  but it should be charged with high  current low voltage  so you can get a larger rotating current traped inside the soft iron
well this is all good but what do you do with it
hummm lol
i wound 600 turns of 28 ga wire  i will now wind the second coil the same dirrection  and see how well it will lock togather
HopeForHumanity
Quote from: singerxyz on November 09, 2007, 02:01:34 PM
Giantkiller,
very exciting!
ha ha!
Some people would just give up at that point, but instead of surrendering to the meter, you didn't give up. HUNT THAT ENERGY DOWN!  :D
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
singerxyz
Version 2
I apologize for the cheesy diagram, best I can do now. If someone want to do a schematic, go for it.
I will also make a cheesy version of the pulse circuit this week- also very simple, like 2 transistors, 5 resistors and a capacitor.
