TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
poynt99
how i believe the OTPU is laid out.
similar to wattsup's.
there are 3 support legs, but i show only two. the 3 legs appear to be wood, with a hole bored out for a core of some type. the hole is not bored through to the top though. the core must be ferromagnetic for the activation magnet to "adhere".
the third back leg is obscured some so a guess is that another coil of some sort is taped up there with green tape. not sure if the core in the leg is being used there.
no collector coil has ever been found, so it must be the red speaker wire. if a 90 degree coil relationship is part of the device modus operandi, this configuration works too.
it's a good bet that the heavier of the two coils is the output coil, and in the OTPU this is the toroidal one.
higher res pics are available if anyone wants them. let me know where the upload link is here.
poynt99
doesn't look like anyone wishes to discuss this (old news i guess), but here are the high res uploads anyway:
http://www.overunity.com/index.php?action=tpmod;dl=item104
http://www.overunity.com/index.php?action=tpmod;dl=get106
Grumpy
maybe the coils that you refer to as the "kick" coils are the iron delay coils
        -Frank Edwards
innovation_station
@poynt99   if you drew those  verry nice work ....
you must be awafually close in thease drawings i think they are transformers in the legs that have been rewound... to be used as kick producers
but im almost sick of the tpu game to be honest
why dont you just tell us how your toy works.....
ist
in your drawings there is no core in the outter wind would this mean it creates an external magnet feild wich is drawn to the cores of the transformers??  createing a magnetic feedback loop?
Vortex1
Nice renderings, Poynt
Makes sense that ferrite rods would have to be protected by an outer cover, they are quite fragile and easily broken if unprotected. The ends of the ferrite rods could couple to the opposing rod and produce a wide magnetic field.
I have no working theory for this device, I can only add that if SM's careful touching of the outer bifilar winding is not a ruse, at least ten amps of current need to pass through the coil (@18ga) to be marginally safe to touch. One amp bulb current would not produce such heating. The outer winding does not seem to make a direct connection to the filter unit so something else must be causing the heating. White wires do seem to connect to the output.
Anyone have a comprehensive workable theory with experimental proofs that they can post in a single pdf?  Marco ? Grumpy? GK? Mannix?
I like the x-ray vision, what program did you use....does it have a steep learning curve?
