F.B.D.I.S.S.M - Flux.Boosted.Dual.Induction.Split.Spiral.Motor.
Started by Honk, October 11, 2007, 02:30:42 PM
mr.uu
Quote from: Low-Q on August 08, 2011, 05:12:10 AM
By multiply the magnets, you just multiply the impossibilities. I have said this befor, but I'll say it again: If one magnet doesn't work, several magnets doesn't work.
How come? I can't follow you on that one.
If i have one magnet at the sticky point and (let's assume) ten pushing/pulling the wheel forward, then this must make a difference.
Analogy: if i alone can not pull a truck, then my power multiplied (me with nine friends pulling) just multiplies the impossibility?
@Honk:
sorry, i did not clearly state, that i was not referring to your replication, but to the pics in the presentation.
Honk
The force from more rotor magnets will never add up to the force needed to escape the sticky spot.
It doesn't matter how you align them or what shape and size they have.
The force from each magnet, attracted or repelled, is very small compared to the total force at the end.
This means that adding more magnets will never let it reach the force needed to push the last magnet
across the gap into next revolution. And none electromagnet can be used to bridge the gap into overunity.
All an electromagnet does is converting external energy into the extra force needed to run a Magnetic Wankel.
Well, here you have it again mr.uu. The sincere truth, take it like an educated man.
Magnet Power equals Clean Power
hartiberlin
Honk,
did you ever try the Steorn principle with 2 toroid coils in 180 degrees out of phase ?
Okay, if you have the last magnet pretty much next to it then the flux of this magnet will also
go into the toroids, when they are not energized and could maybe saturate them.
Depends on how big you buiild these toroids. These would probably need to be build
quite big then to not getting saturated by the last stator permanent magnet flux.
But if you energize then the 2 toroids coils, then the 2 toroid´s core will get totally saturated,
so they behave as aircore coils and are no longer magnetic, so the rotor can freely move on...
That should work, if you build it right.
Maybe one needs to build more elliptical toroidal cores and coils around them
to fit the Stator permanent magnet track at the end...
Would be interesting to see an experiment like this...
Regards, Stefan.
Acca
Just dropped in to and to find out that this is a very old thread and now some good news the Russians have made a motor generator that is what you are after
there is No back EMF as they switch the stater field in their motor and have an armature that is also feed through two slip rings..
All of this project is in Russian and there is allot of videos and NONE have made it to the West ... Wow what a shocker as Jim Murrey and Paul Babcock have spent
https://www.youtube.com/watch?v=YhaAxQjyeC0 ) years trying to get rid of back EMF from motors, and it looks like the Russians have done it !!!
links below .....
https://www.youtube.com/watch?v=11UKJ0z8lqg
http://vk.com/globalwave2012
https://www.youtube.com/watch?v=zYYynctrQog
https://www.youtube.com/watch?v=7k53zY3z1yI
https://www.youtube.com/watch?v=f0rWCNDWBjA
https://www.youtube.com/watch?v=QveoN9Jjb6A
https://www.youtube.com/watch?v=w5Nk1zrEyLE
https://www.youtube.com/watch?v=2gJmHxVcyCQ
https://www.youtube.com/watch?v=I2EQg3G36MA
https://www.youtube.com/watch?v=578G5CtLsVk
Acca..   [/font][/font][/font][/font][/font]
