0 Members and 18 Guests are viewing this topic.
DrStiffler
Quote from: alan on April 05, 2008, 11:21:47 AM
What is wrong with my idea of putting a generator to the motor to convert the event to regular current, since no-one is responding to my comment?
@alan
Hey, nothing is wrong with your idea, but it is not as simple as it sounds. Obtain a generator with know specifications, devise a coupling method. The RPM method the was proposed does work and is simple to implement. To bad EMDevices had his feelings hurt, guess mine could be, but his could not, anyway it was a good idea and only took a short amount of time to try.
When you get to the mechanical things a whole world of additional problems pop up and sometime, like with me, I'm not a great mechanical person.
Thanks, don't get upset, great idea.
All things are possible but some are impractical.
Loki67671
@All,
A little of the work done today. It's even lighting up the AVP in the middle of the de-energized SEC down bottom there. I think I can even post this one by myself.  ;D
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Loki67671
@All,
Most of everything there is, is in this state! I can explore this circuit for hours on end.
Best
Jim
Gustav22
Thank you fritz and and doc for your replies.
BTW, Doc, when I go to http://www.stifflerscientific.com/
and then click on the first menu item "Main Section"
the link points to
http://67.76.235.52/ce4.asp
But then I get
"The page cannot be found"
(also tried this yesterday with same result).
money for rope
Loki67671
Quote from: aluka on April 05, 2008, 01:11:10 PM
The missing photos:
@aluka
I'm not kidding you when I say I've seen this with LED's in many places. Have a look at the center AV plug. In the upper left of the photograph is a SEC exciter driving an AV plug with 1 large Neon bulb. I'm working on finding the tuning for heat production. While I'm tuning I run into a spot where the center AV plug of a de-energized SEC exciter, upper right, lights up and adjusts with the tuning of the the other circuit. Do you think currents are flowing all around us all the time? I do for sure!
@All
Will be a little bit limited today due to the impending taxation deadline here in the US. I have procrastinated far too long! But I will be tweaking later, hopefully..................? I'm working on heat!
Best regards,
Jim
