0 Members and 18 Guests are viewing this topic.
samedsoft
Quote from: RStiffler on May 11, 2008, 01:48:55 PM
@ALL
When is Hot, Hot enough? See New video.
http://www.youtube.com/watch?v=FmsKHmGq0ec
@Dr. Stiffler,
  You are apperently measuring COP = 2 is that correct?
   Please make sure that you do not look directly to the ball lightning!! We need your eyes :)
    Best Regards,
    Nuri Temurlenk, Turkey
DrStiffler
Quote from: samedsoft on May 11, 2008, 02:59:28 PM
Quote from: RStiffler on May 11, 2008, 08:13:01 AM
@samedsoft
A number of years ago I looked at what I could find on Dr. Chukanov's work and at that time detail were few so I have not paid further attention. The last I saw was that he was working in Canada?
I have received information (unconfirmed) that a researcher using a SEC Exciter built a five (5) terminal
Ne bulb with (4) terminals at 90' locations and a terminal in the center of the circular arrangement.  He states he drive opposing electrodes from two AV Plugs off the exciter. The center electrode is at earth ground. It is stated that a very hot ionization forms around the centered grounded electrode.
Much to my dismay I do not have the capability or knowledge to build bulbs like this, but hoping to obtain one. If reports are correct, this would be a possible answer for a productive Exciter.
Has the good Doctor an underlying theory?
@Dr. Stiffler,
   I can assure you Dr. Chukanov is the leading researcher in the field of ball lightning. He has done RF excitation on 1994. Please check http://www.google.com/patents?id=nNIaAAAAEBAJ&dq=5537009
  He has resolved the nature of ball lightning and he found how to convert gas into plasma state and then to ball lightning state. He has now world's biggest stable synthetic ball lightning reactor. He has patented microwave excitement as well at http://www.google.com/patents?id=HXIVAAAAEBAJ&dq=6936971
  He releases very good information on his patents and he is renewing his web site on these days. http://www.chukanovenergy.com/images/pdfbook/Ball_Lightning.pdf has introductory information on his findings.
  He notes that ball lightning event releases soft X-Rays, UV, IR and visible light..  This is important for SEC experimenters to secure their eyes!!! I am willing to purchase one but I am still waiting for Stefan's experiment results on SEC device COP calculations....
  I will consult Dr Chukanov about optimum gas selection and pressure for SEC device in order to obtain best heat output.  I will let him know about your discoveries as well.
  Please try to read patents and ball lightning book when ever you have time...
  I am looking for your comments.
  Best regards to all SEC experimenters,
@samedsoft
Please do not take anything I say as a negative on the Dr. I tried the link you supplied in a few posts back and maybe because I use FireFox I could not really see anything, I tried loading a few of the (.pdf's) and just received blank screens.
Anyway, I will look further as you have advised, although I firmly feel this is not the ball lightning effect, yet I beleive it may come from the same interface to the energy lattice through wide bandwidth excitation. I hope the Dr. is not feeling that I and duplicating his work as I can be so bold as to say I have as yet to exceed 30W, far from a 500kw unit.
Anyway to answer you next question, my videos are honest and speak for themselves.
Thank you for the responses.
BTW: I do indeed protect my eyes....
All things are possible but some are impractical.
Loki67671
Quote from: RStiffler on May 11, 2008, 01:50:55 PM
Quote from: Loki67671 on May 11, 2008, 12:33:49 PM
Plugs right into the PC.  ;D
Loki
Why did you not leave it connected as when you did your initial testing? We have all seen wiring!
So where does your calibration method fit in?
The RS485 network is going through the floor into the pit/basement. I haven't routed the cable yet and I'm going to control the temp in a small area downstairs so I'm not trying to heat the planet. The calorimeter will run downstairs, the PC upstairs. The wiring wasn't the point yet unless someone saw a potential noise problem that I'm missing. The initial testing is just communications testing to see if the surplus garbage actually functions and reads from the jumpered in and as yet uncalibrated temp sensors, which it seems to. Calibration of the calorimeter will be done exactly as you have said, with a big old power resistor and and known input power, obviously after I'm done putting together. Part-time work is unfortunately slow.
Loki
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
DrStiffler
@samedsoft
@Dr. Stiffler,
@samedsoft
I hope that Stefan understands that the SEC15-20 was not built for this type of testing. In order to test for excess heat he will be required to drop (cut) the chaining from the first AV Plug and move the Neon back to the first position (as in the SEC15-3) and then add the parasitic plate and additional capacitor. If not, the the SEC15-3 was not stated to be able to show excess heat (see www.drstiffler.com/) and the SEC15-20 will not because of the added LED's.
Just a heads up on this...
Also there are very few SEC Boards left and the link to purchase same will be removed in the next few days. I do not intend to order additional boards.
Loki67671
@ALL
Yes I do believe I have it. A ball of fire. 140F gun measured neon  24.12VDC @ 36ma power input. I just couldn't cook my only board. But now that problem is solved.  ;D I will get results just as soon as I can. Sorry for the delay!  8)
Jim
