Loki67671
@All,
Stability is achieved!  ;D The DAQ system is running as 4 differential channels and everything is sharing a common ground point that is not earth ground.  ;) The monster is running down in the dungeon right now and a PC is logging the performance.  ;D It is not calorimetry yet but I'm getting there. Is anyone else going to perform calorimetry on this device? I'd like to hear some other experiences with this. Here are some shots of the electronics. Oh, the sensing resistor has been changed out to a 1.5 Ohm, 1%, 1 watt ceramic. Not enough current flowing in this circuit to use the 0.050 Ohm sensors.
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Loki67671
@All,
The visuals tell the tale for me. The spikes are me picking up and moving the temp sensors. The dip in the red trace is the sensor for H20 when I put it into the SS vessel. The other two are sitting side by side tucked just under the left corner of the monitor. Now from this I will look for overall system stability. Next I'll completely assemble it and start dumping some known energy into the mass as a whole, obviously after I water bath calibrate those temp sensors but that will simply be done after assembly.  ;D Green trace is Power input. I'll be fiddling with some additional decoupling too to smooth things out a bit further.  ;D Data is being sampled on 1 minute interval and logged into Excel.
Best regards
Jim
gotoluc
DrStiffler
Quote from: gotoluc on May 31, 2008, 02:40:14 PM
Hi all,
I have a new video available which is better quality ;D
Link: http://www.youtube.com/watch?v=NCbXJDK7Pco
Luc
@gotoluc
EXCELLENT! (Yes a new coil is on the way to you)
This is what I have wanted for so many months now, "Take the Bull by the Horns" and show it who is boss.
Now for a bit of help, although you are doing very well on your own!!!!
*Get the SEC Exciter as close to the cell as possible. You are suffering a contamination of available energy by ionic current. The long leads from the SEC Exciter to the cell are drawing ions from the environment and canceling out the excess spatial energy.
Try moving it closer, please?
Okay, because you can not tune yet, there is a problem that will have to wait for correction (mail receipt).
Where are the smaller bubbles coming from, the anode or the cathode, I would bet the cathode??? This is a case where the balance of H2, O2 release is not in balance. See my video where there is only H2 released.
When you get your new coil if you are stocked with 1N4148's I will help you increase by 4X.
Great, Great work.
All things are possible but some are impractical.
gotoluc
Thanks Doc ;D
I'll try to see from what side the bubbles are coming from and make the leads as short as possible and post a new video if it works better.
Luc
